Where to get compression test done?
Old Jun 16, 2006 | 04:26 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by vanillagorilla
So you're not coming down this weekend? We can figure that ish out at mi casa...assuming your truck can make it. I've messed with adj. rockers more times than a care to remember.
I'm still coming. And yes, it will make it. Still runs fine, just that bank 2 is lean when I am higher than 10hg-in vacuum.
Old Jun 16, 2006 | 04:33 PM
vanillagorilla's Avatar
Higher like 11" hg or higher like 9" hg?
Old Jun 16, 2006 | 04:41 PM
thunder550's Avatar
Like 11". More vacuum = bank 2 lean. Less vacuum or getting into boost = bank 2 same as bank 1.
Old Jun 16, 2006 | 04:53 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Just keep it in boost ALL the time
Heres the part where I sound like an *** but I'm not trying....Are you using a Tq wrench when you do these rockers or winging it by feel? What makes you think some may be too tight? I know the way it runs is leading you to that but if you used a Tq wrench and and have double checked the Tq value, why would they be too tight?
Old Jun 16, 2006 | 04:56 PM
thunder550's Avatar
The procedure for tightening them doesn't mention torque anywhere, so no torque wrench. There is a process to bleed down the lifters which basically involves getting the nuts just barely tight, tighten 1/4 turn, wait 10 minutes, repeat 7 times, then tighten down one last time and crank the locking nut thingy down at the same time. They didn't "feel" the same this time as they did the first time I did it, but since it fired right up on the first shot I figured everything was fine. Maybe it is, but it's just one more variable to eliminate.
Old Jun 16, 2006 | 05:08 PM
1SlowHoe's Avatar
Hmmm. Ive never messed with adjustable rockers either. Sounds like they are a pain to get setup. Good luck figuring it out.
Avalanche2002
Nov 30, 2015 07:31 AM
BlownHD
Oct 3, 2015 12:24 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
