when to replace a PCV valve?
Old Jan 13, 2005 | 07:55 PM
KeukaZ71's Avatar
Default when to replace a PCV valve?
do you guys include replacing the PCV valve in routine maintainance? at what mileage do you change it? my Haynes manual says 60k miles. i'd rather here it from you guys first hand.
also, what about the EGR valve?
Old Jan 13, 2005 | 08:58 PM
BLASTER's Avatar
I did the PCV valve at about 47K. Nothing wrong with it but it was only 5 buck so I replaced it anyway. With the truck off it should rattle. What you also want to do is is to start up the truck, pull out the valve and check to see that it works by putting your finger over it and checking for vaccuum.
Old Jan 13, 2005 | 09:21 PM
yeary03SS's Avatar
If you're losing a lot of oil between oil changes it might be time to replace it.
Old Jan 13, 2005 | 09:38 PM
sleepersilverado's Avatar
dont wory about the egr. it is not something that you would replace unless it goes bad and you will know because it will set a code.
Old Jan 14, 2005 | 05:04 PM
KeukaZ71's Avatar
thanks guys. that helps alot
mhorn0817
Jul 8, 2017 01:54 AM
The_W
Oct 28, 2015 09:00 PM
Fast86z
Aug 23, 2015 12:35 AM
jroctpb
Aug 11, 2015 03:52 PM
Mzay
Jul 6, 2015 11:03 PM
