What's it take to build up a trans?
Old Feb 24, 2004 | 09:46 AM
StreetSweepa's Avatar
Default What's it take to build up a trans?
I'm thinking about trying to get my transmission built to make it stronger for more horsepower. What's it take to get this done? Do you just buy certain new parts to put in the transmission? What's something like this usually cost? I don't want to have to worry about the tranny goin out....planning 450-550 horsepower.
Old Feb 24, 2004 | 09:53 AM
If you are just talking about buying the parts, then do a internet search for "high performance + 4L60E". You'll find a couple of places. I went with PATC. I called them and they told me what I needed, verified it with my tranny builder, then ordered the parts. About $750 for the parts. Will be more for you if you go up to 5-pinion planetaries.
Old Feb 24, 2004 | 10:01 AM
Flyer's Avatar
I went to them as well ... they are local to me. Here's what I got from them.
Master Rebuild kit (all new clutches and gaskets with blue 3/4 clutches)
Billet servos (Intermediate and overdrive)
billet 1-2 accumulator piston (mine was cracked when it was tore down)
Torque Drive system (which includes a hardened input shaft, input drum and a reaction shell better than 'The Beast')
New GM Drum
Raybestos Pro Series Band
And a new piston and spring set that goes with the Torque Drive system.
I think that's it .. but it all added up to be about 750 or so.
I was going to try and rebuild it myself, but I ended up having someone do it for me.
Old Feb 24, 2004 | 10:11 AM
What did installation cost?
Old Feb 24, 2004 | 10:21 AM
Flyer's Avatar
Mine was more of a favor ... I pulled and put the tranny back in place.
Old Feb 24, 2004 | 10:26 AM
Should only be $4-500. My parts will go in next week. A couple hundred less, if you pull the tranny yourself - should be anyway.
Old Feb 24, 2004 | 10:35 AM
Flyer's Avatar
Most places don't like to do bench jobs so they can make sure everything is replaced correctly. I can understand why since they have to put their name on a good tranny in a bad install and have to replace and fix what you broke.
Old Feb 24, 2004 | 11:08 AM
GREGGO's Avatar
Have you contacted any of the Tranny shops over on the side?------>>>>>>>>>>>>>
TCI has some great parts and a lot of guys swear by them. I talked with them a while back, but decided to go local with a shop since I will not be pulling it mself.
Old Feb 24, 2004 | 12:01 PM
Flyer's Avatar
If I was going with a sponser built tranny, I'd go FLP all the way.
Vash3233
Sep 22, 2019 01:18 PM
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Aug 14, 2015 10:28 PM
walledition
Jul 29, 2015 08:54 PM
Deceptarado
Jul 8, 2015 05:24 PM
