What is needed to make the 14's?
Old May 1, 2005 | 01:07 PM
Default What is needed to make the 14's?
I have an '03 RCSB Chevrolet Silverado with the 4.8 liter and 3.42 rear. I ran at the track last week, and right off the street (30 miles there) I ran a 16.2@83mph...and, hot-lapped it to a best of 16.1@85 4 passes later. All 60's were in the 2.5 area, and were all run on 17" Avalanche wheels with 275/60/17 BFG's. I honestly think that the taller wheels/tires slowed me down a bit from a dead stop, but the truck did NOT spin a bit when I would launch...so I think the added height/weight killed it a bit. What do I need to hit the 14's? THat's all I want out of the truck..and, I seriously think it's got a 15.7-ish in it as it..with stock sized tires on it. I want LT's, and full exhaust, but I also want to keep the stock gearing in the rear, b/c I do alot of highway driving. A buddy of mine has a custom grind lunati cam that I had in my Trans Am, in his room...it was a "stealth" cam..I don't remember the specs on it off-hand...but, it made 330rwtq at 2,800rpm..and, then steadily climbed from there..so I figured that might be a decent cam for the truck..am I wrong? I don't want to do a stall converter, as I will be using the truck to pull my car, but I still want to be able to do some sort of damage on the streets with the truck....
If anyone has any suggestions, I'm open to any/all of them. Also-I do NOT want Nitrous..as, I want the power there all the time!!!
Thanks In Advance,
Jason
Old May 1, 2005 | 01:32 PM
Gran Patron's Avatar
Get a Good tune!!! Nelson Permormance has a good tune!When runing at the track lose some weight like the tailgate and the spare tire. Try the healight mod by removing the left headlight straight air flow. LT's will help your time and exhaust. 3:73's will help not much difference in gas but better accelaration. They should help you het High to Mid 14's
Old May 1, 2005 | 02:02 PM
What would I be changing with one of these tunes? I've heard that these trucks pull timing at WOT? Is it possible to run a 14, without touching anything internally in my truck? Maybe gears/exhaust and tuning?
Old May 1, 2005 | 02:03 PM
litreddevil's Avatar
Banned
Well alot of my friends are running trailblazer converters and they use their trucks to pull their race cars to the track.e-fans ,pacesetters,pulley,coldair,custome tune by Thunder Racing.We have x-cabs with 4.8 running 14.5s.some are running the 6.0 truck cam and some are running the 2001 ZO6 cam.
Old May 1, 2005 | 02:54 PM
What is the trail-blazer converter? I mean..I'm gonna go out on a limb and say it's from a trailblazer..but, what's the difference?
Old May 1, 2005 | 03:16 PM
Daniel's02GMC's Avatar
13 Second Truck Club
Default 14's
i have intake, exaust, shift kit, Ls1 Fans, and a Nelson Tune and i should run in the 14's i have a rcsb 4.8 w/ 3.73's i ran i 15.4 on friday but that was w/ a clogged muffler and 100% humidity but i would definetly put in 3.73's i still get about 14-18'ish mpg i think it will run a 14.8 now
Old May 1, 2005 | 07:55 PM
F8L Z71's Avatar
Are you in high elevation or something?
Your MPH seems really low for that truck.
Mine with no air filter and a raceweight of 4450lbs ran 15.5@89.9mph on a 2.36 60' roasting the right tire. LOL
I was going to try and run again last week but I got rained out. I was trying to see if just the addition of a tune and better traction would get me the 14 I think I can get.
I think all you need is a custom tune, ghetto fab intake, muffler, and the truck in good running condition to get a 14 unless you have lots of extra weight on the truck. At the worst you can get the stall converter and some shorter stickier tires and you'll be there.
Old May 1, 2005 | 08:08 PM
ThunderZ28's Avatar
12 Second Club
Gears, posi, converter, and a tune will get you in the 14's.
14.5's to be exact...
been there done it..
was running 15.5's with 3.42's, open diff, stock converter, and a HPPIII, swapped out to 3.73's, Eaton posi, 2800 stall, and LS1 Edit, dropped straight into the 14's with those swapped
Old May 1, 2005 | 08:37 PM
02chevyracing's Avatar
14 Second Truck Club
what are you running now thunder?
Old May 1, 2005 | 08:50 PM
CAMMIN03''s Avatar
Banned
Tune..... LT's and Gears......... I just dont see that dropping him a second to 1.2 seconds
Get the nelson tune.... 3000 stall.... LT....... 4.10's... and a Cam then you should be there....
On another note......Im not sure why i type with so many periods......haha.....I know....I am an idiot....what can i say Go Dawgs.
