What mods to a stock airbox
Old Jan 12, 2009 | 05:57 PM
skyhighsami's Avatar
no title here
That is a little more "ghetto" than I had in mind. I will look into it more this weekend to see what I might be able to do with it on my wife's Yukon
Old Jan 17, 2009 | 09:20 AM
rommrh's Avatar
You can remove the baffle on the intake tube (large removable baffle on bottom beside radiator. Then replace it with a paint cap. Take an old grinding wheel or cut off wheel and remove the ridges inside the airbox. Make it smooth so air flows better across the box. Port and polish the throttle body, by-pass throttle body and remove the egr with a block off kit. The block off kit might cost 14 shipped from speed inc, and the bypass kit is a few bucks off ebay. I dont know how much bypassing the throttle body cools the air charge, but I would imagine removing the egr cools it slightly as well as allowing more airflow.
http://www.bowlingss.com/LS1_How_To.htm
http://www.bowlingss.com/Mods/Instal...Free%20Mod.mht
Old Jan 18, 2009 | 09:27 AM
no title here
I have already bypassed the coolant lines and it was free, being that it is an 04 I don't have EGR to block off. If I cut the air box behind the headlight and sealed it to the core support with foam would that be good? Maybe cut a hole in the bottom of the box and put a 3 or 4 inch PVC with an elbow to pull the air from behind the valance. Would I need to block off the opening to the fender in all of this?
Old Jan 18, 2009 | 11:15 AM
GMCtrk's Avatar
The box is definitely a restriction. On the dyno I picked up 10 rwhp by bypassing the airbox. But it may have been exaggerated because the truck was stationary with no air flow (there was a huge fan blowing of course). I think the best bet is just an open cone filter.
Old Mar 31, 2009 | 03:58 PM
jay-rad91's Avatar
how do you bypass the airbox? im new to this site and still tryin to figure it out so bare with me plz hahaha. i have an 2001 silverado ext. cab with the 4.3 V6 and im tryin to squeeze as much hp out of it as possible. if it works on my truck, i will also do it to my 08 infinity G35. it has dual airboxs and intakes on the damn thing! double the power gain! hehehehe
Old Mar 31, 2009 | 04:08 PM
95 bright teal's Avatar
lol! he removed the box completely, not something you want to do on something that gets driven, you will be sucking leaves and poor innocent squirrels straight into your motor
Old Mar 31, 2009 | 04:29 PM
jay-rad91's Avatar
lmao about the squirrells ohh ok well that makes sense. any other mods i can do?
Old Apr 4, 2009 | 08:56 AM
jay-rad91's Avatar
ok what i did with my airbox is i cut out a large hole in the front of the box right behind the headlight. noticeable difference. improved throttle response and a little more hp. i just run during the day with my headlight taken out, then at night i pop it back in.
Old Apr 4, 2009 | 09:11 AM
sonoma43's Avatar
you really dont need to drive everday with the headlight out.....you will look like an idiot and its not gaining you much at all!
good idea for the track but not everyday driving
ARC
57
Feb 21, 2022 10:54 AM
thewrx
Aug 12, 2015 08:28 PM
bk_cauley
Jul 19, 2015 09:56 PM
black6spdz
Jul 16, 2015 01:32 AM
zaathur151
Jul 6, 2015 10:57 PM
