what do i need to install headers
Old Jul 11, 2005 | 07:48 PM
jerome's Avatar
Default what do i need to install headers
http://store.summitracing.com/partde...=KeywordSearch
those are on the way.
what tools or supplies do i need to install?
thanks
jerome
Old Jul 12, 2005 | 07:47 PM
ReedyCreekRacin's Avatar
basic hand tools, an air ratchet would make things go a little faster. dont forget beer. CHIP
Old Jul 12, 2005 | 08:17 PM
jerome's Avatar
do the header bolts need to be fastened using a torque wrench?
do the gaskets have to be greased or anything? should i get copper ones instead of using the supplied ones?
i have heard people put anti-seize on the bolts? is that a good idea?
thanks
jerome
Old Jul 12, 2005 | 11:51 PM
BigJ's Avatar
Header bolts need to be torqued to spec. Do a search or someone will chime in, I forgot the specs. Re-use your stock metal gaskets, no grease. If they are over 2 years old, I would replace them with OEM, but the stockers work great. I would replace the spark plugs while you have the exhaust manifolds off, makes it simple. NGK TR55 gapped @ .50-.60 work good (assuming your stock, ie. no supercharger or nitrous). Use anti seize on the plugs. I would use anti seize on the header bolts too. After your done, make sure your plug wires are not touching your headers. You will be able to push or pull them out of the way. Thats about all I can remember right now. Hope that helps.
Old Jul 13, 2005 | 07:49 PM
78' Silverado's Avatar
Pretty much wat they said above....
But one question...Why not spend another 100 and get FL lol.
zblee
63
Jun 10, 2023 01:25 PM
2500ZL1
Jan 25, 2016 06:30 AM
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
