What cam. What stall
Old Nov 13, 2011 | 06:05 PM
kogelch's Avatar
Default What cam. What stall
Im sure this has been asked and explained multiple times but, i am looking for a good torque cam for my 99 5.3 liter that will work best with the mods I have. My Mods are listed in my sig. Im not looking for anyting extremely radical. I drive the truck to work everyday. And use it to plow snow in the winter. Also do I need a better stall converter. If so any recommendations. I heard there is one out of a trailblazer that works well. Is that true. Suggestions would be great. Thanks
Old Nov 13, 2011 | 06:45 PM
Chevy_King1500's Avatar
212/218 low lift
the converter out of the i6 TB works well.
sell your MAF and your hand held tuner
Old Nov 14, 2011 | 08:12 AM
kogelch's Avatar
Whats wrong with the MAF. What do you recommend for a MAF. I6 = inline 6 correct.
Old Nov 14, 2011 | 08:21 AM
Harbinz51's Avatar
That MAF has terrible resolution for custom tuning. Throw it away(sell it) and put the stock one back in. A TR220 wouldnt be a bad choice either on the cam IMO.
Old Nov 14, 2011 | 10:42 AM
hernhe5708's Avatar
I went tr220 on my 4.8, decided on a 3200 from circle D... Just waiting till Thursday to order the verter... Cam is on route
Old Nov 15, 2011 | 07:27 PM
kogelch's Avatar
Do you know wha years the tb had the inline 6 converter i need. Thanks for the help.
Old Nov 15, 2011 | 07:38 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Plowing snow with the 4L60E is what raises my eyebrows. Taking that into consideration, here's my suggestions.
A built transmission is a must. Plowing with the t-case in low range is a must. Adding a larger transmission cooler is a must. I would not recommend a TB converter, or an aftermarket high stall converter. The larger diameter stock converter is what I'd stick with, and should work okay with the 212/218 low lift cam. No way in hell I'd recommend a TR220 and a converter for snowplowing.
Also, I agree with selling your aftermarket MAF and putting the stocker back in. Top it all off with a good tune, and you're all set.
Old Nov 15, 2011 | 07:54 PM
kogelch's Avatar
Great. Thanks
Old Nov 15, 2011 | 10:21 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
yep, TR220 is gonna need at least a 3600 stall converter. stick with the low lift cam.
Old Nov 15, 2011 | 10:28 PM
allenp's Avatar
nice setup =]]]
