What cam. What stall
Im sure this has been asked and explained multiple times but, i am looking for a good torque cam for my 99 5.3 liter that will work best with the mods I have. My Mods are listed in my sig. Im not looking for anyting extremely radical. I drive the truck to work everyday. And use it to plow snow in the winter. Also do I need a better stall converter. If so any recommendations. I heard there is one out of a trailblazer that works well. Is that true. Suggestions would be great. Thanks
Plowing snow with the 4L60E is what raises my eyebrows. Taking that into consideration, here's my suggestions.
A built transmission is a must. Plowing with the t-case in low range is a must. Adding a larger transmission cooler is a must. I would not recommend a TB converter, or an aftermarket high stall converter. The larger diameter stock converter is what I'd stick with, and should work okay with the 212/218 low lift cam. No way in hell I'd recommend a TR220 and a converter for snowplowing.
Also, I agree with selling your aftermarket MAF and putting the stocker back in. Top it all off with a good tune, and you're all set.
