What cam. What stall
Old Nov 19, 2011 | 03:47 PM
darnie's Avatar
Originally Posted by b4vwannabe
yep, TR220 is gonna need at least a 3600 stall converter. stick with the low lift cam.
idk..... im going with a 3000 stall with mine.... should be just fine? just my 2cents
Old Nov 19, 2011 | 06:31 PM
1slowz71's Avatar
212/218 low lift is great. That tr220 is a tad to much duration for what your looking for .....darnie your gonna need more converter ....I'm 6.0 with a 3500 stall and my cam is a 228/232 and my power band don't start till like 4k , so I can only imagen that tr220 on a 4.8 with a 3k .....but hey what do I know .....
Old Nov 19, 2011 | 06:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by AKlowriderZ71
Plowing snow with the 4L60E is what raises my eyebrows. Taking that into consideration, here's my suggestions.
A built transmission is a must. Plowing with the t-case in low range is a must. Adding a larger transmission cooler is a must. I would not recommend a TB converter, or an aftermarket high stall converter. The larger diameter stock converter is what I'd stick with, and should work okay with the 212/218 low lift cam. No way in hell I'd recommend a TR220 and a converter for snowplowing.
Also, I agree with selling your aftermarket MAF and putting the stocker back in. Top it all off with a good tune, and you're all set.
Sounds like somebody is on the rite track...
Old Nov 20, 2011 | 10:18 PM
TTownTech's Avatar
tr220 would def. be a bit much for something thats gonna be doing snow plow work too. but thunderracing recommended it to me after i told them what i was doing and going to use a 2800 stall, he said it was bit tight but id still be ok with it.
--- lol ignore harbinz51, he traded off a clean 07 gmc for a broke down f250 lol
Old May 3, 2012 | 07:35 PM
kogelch's Avatar
Is that the LSx cam. After looking around i think this is deffinately the cam i want but i want to make sure im looking at the same cam your reccommending. Please check out the link and let me know if i am looking at the right one. Also other then valvetrain upgrades is there anyhting else that needs to be done to make this cam work in my truck. Thanks again for th eadvise. Comp Cams 212/218 LSx Cam "LOW LIFT"
Old May 3, 2012 | 08:09 PM
Beatdown Z's Avatar
Laid Back
That's the one.
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
Wolftrk99
Oct 2, 2015 08:17 AM
JoshH
Sep 28, 2015 11:19 AM
bisqikss
Sep 27, 2015 09:40 PM
