Vortec Max/VHO oil cooler added to 5.3?
Old May 12, 2006 | 08:40 PM
MonteCarlo31's Avatar
Default Vortec Max/VHO oil cooler added to 5.3?
Is it possible to add a factory oil cooler to a stock 5.3? Thinking this would help lower my overheating problem when towing or sitting in traffic with these crappy electric fans. Also thinking of buying a 04 fan shroud and clutch fan to replace my electric ones or maybe use a horton electro clutch driven fan.
Old May 12, 2006 | 09:39 PM
spitfire2332's Avatar
yes, the oil cooler is an option on the 5.3Ls
Old May 12, 2006 | 09:55 PM
03lowriderss's Avatar
does any one have a pic of this oil cooler installed on there truck?
Old May 12, 2006 | 10:00 PM
I'm pretty sure the factory oil coolers are right in front of the radiator. If I look through my grill I can see mine. Pretty much looks like this, just not as nice...
and part numbers please!!!
Old May 12, 2006 | 10:05 PM
03sierraslt's Avatar
When do you expirence overheating? Just when towing?
Old May 13, 2006 | 07:26 AM
Rammer's Avatar
Factory Transmission Cooler - 12497071
Recommended for upgrading to a trailering system. Helps prevent transmission overheating. This kit includes the cooler, lines and everything needed for installation.
Old May 13, 2006 | 09:30 AM
Quik's Avatar
5 year bitches!
i used the LQ9 cooler and also used the rad from a SSS on my RCSB setup. my truck used to be a 5.3 now a modded 6.0 so yes it will work but if you do it factory way you will need the larger rad
Old May 13, 2006 | 10:32 AM
Truck already has a 34" rad from the factory but not with the built in cooler. I have the trans cooler on my truck already. I experiece overheading when towing only yes. On the road the electric fans are ALWAYS on reguardless of A/C. The only time they cycle is when it's in the low 60s. I am sure the problem is the electric fan that these trucks have without a doubt.
Old May 13, 2006 | 10:47 AM
Quik's Avatar
5 year bitches!
buy a tank and have it added to the rad. the tank was bad on my rad so i had a new tank crimped on so i can have the cooler again
