Vortec headed 355 sbc with center bolt headed 305's intake/TBI
Aye, fellas! First off, awesome site! Second, I have a carbed 355 with vortec heads tha I want to put in my 1990 2wd Silverado 1500 which currently has a 305 in it. can the intake/TBI be used as a direct bolt on? I was figuring it would with both engines having center bolt heads. If anything else is needed please let me know. Thanks!!
It will be fine but you are going to have to find someone to custom burn a chip or it will run terrible.
My experience on all TBI stuff is the early computers suck. I always swapped out to a 95 pcm and had a chip burned it was the best chance at any hint of driveability with a cam.
Once done they alway's run better the 95 pcm's are waaay faster and can respond to changes in map from a cam better than their slow predecessor's.
Just find a donor truck get the computer and cut about a foot of the harness off behind the pcm connectors. Then get out soldering gun heatshrink and a diagram and begin the retrofit. With the 95 pcm you also change to a heated HO2S which also helps out a bunch with proper fueling.
Dynamicefi.com if you want to stick with the older style ECM. No chip burning needed.
Use solder barrels crimp solder and heat shrink I've never had a problem w reliability yet and the pcm terminals and connector shells are different in the 93_95 putters vs the 88_92pcms.
The connectors are different but the pins that are attached to the wires are the same and easily unpinned. 85-96 TBI and 85-92 TPI all use the same ECM connector pins on the wire ends but different connectors. It takes me all of 10 minutes to repin the connectors.
Thanks tons, man! As soon as I get my stuff together, Ill update you on tha outcome!
