VHP/Crane accelerate/quick lift rockers.
I got these in the mail today:
VHP / Crane 1.89 (1.8) rockers.
They're nice looking parts... They look good sitting there. They're fun to pick up and play with ever now and then. There is not much else I can say about them at this point.
I'll be installing them hopefully within a months time. We'll see. The install looks a little involved - maybe a 4-6 hour procedure that requires time for the lifters to bleed down. I may end up doing VHP/Crane duals at the same time (which are on the agenda this spring regardless).
those are nice
that reminds me
I need to talk to those Vinci boys
what will that put your lift at?
and what you got those tr55's gapped at?
I probably need to replace my stock plugs
after all the hell theyve been through
that reminds me
I think my lift will work out to be about .562". Not too shabby.
I'm considering pulling out the 047 for your 062 (oooorrrrrr, something else from them), but I'm not sure if the $250 it will cost me in the end to swap/sell cams is worth it to bring the lift up to about .583".
The TR55's - geeze, honestly I forget. Whatever the stock gap is - that's what I set them to.
These plugs are coming up on about 25K miles now. I should pull a few soon to check them out.
They look like a nice piece Marc, What springs are you using now? Get the valve spring tool from them also, It worked great for me.
My tr55s are gapped at 55, I am pretty sure they came that way from NGK
Hey Matt - I'm using 918's right now. I have no complaints with them, but I like what I've been hearing about the Crane duals... I'll probably have to get that tool - I used "the larry tool" before which does them one at a time. I put some wear and tear on it with the 918 install - I reseated some springs like three times each because I'm paranoid about the locks/retainers being pefect.
i have heard stories about that long install. be sure to go at it step by step. i have heard that after they do it that they would not run. they ended up going to the old loose to tight method and adjusted them that way. good luck.
I took the easy way out with the Harland Sharps, I hated doing the valves on the oval track car so I went the easy route. How much preload do they say a Vinci? I just changed pushrod length with the new cam because I think I had too much.
I'm really not all that familiar with rocker setups in cars/trucks... These are asking for an initial setting to zero lash, then 2 turns of preload on the adjusting nut, a quarter turn at a time with breaks in between to allow the lifters to bleed.
These rods are 7.250. I'm currently running 7.4's...
