Valve train noise when engine cold??
Old Dec 18, 2003 | 05:40 PM
  #21
Flyer's Avatar
The GM techs that did mine said the pan is GLUED on. They said there is some special bolt holes on there to wedge it off?
Do you think it would be easier to take the front of the motor off?
Old Dec 18, 2003 | 06:39 PM
  #22
ranwalk's Avatar
When I got the o-ring I asked the parts guy if the pan gasket is reusable. He pulled it up on the comp and said it is?? I guess i'll just get it up the lift and take a good look at it. If the gasket is reusable it seems pretty straight forward. Just drop the crossmember then the pan. The bulletin says it only pays 1.3 hours of labor, so it must not be too hard to do. I would hate to drop the pan then find out I need a gasket or some special sealer though.
Old Dec 18, 2003 | 09:44 PM
  #23
Flyer's Avatar
Get a tube of RTV black just in case. If it were me ... I would replace the gasket and any seals just to be on the safe side though.
Old Dec 19, 2003 | 10:58 AM
  #24
4x4sierra's Avatar
I replaced my gasket, just because I don't like to reuse gaskets. Mine had a small rivet on both sides of the pan to hold the gasket in place.
Old Dec 19, 2003 | 12:34 PM
  #25
Ryan23silverado's Avatar
Just replace the gasket. You don't want to do this twice. Trust me it will take longer than 1.3 hours to do this. There are two rivets in the pan you have to drill out also.
Old Dec 19, 2003 | 05:38 PM
  #26
ranwalk's Avatar
One good thing, i'll be doing it at the shop with a lift and air tools. I didnt get a chance to get a gasket. Do you have to drill out the rivets if you try to reuse the gasket?? Believe me, I dont want to do it twice, but if this stops this damn knocking noise i wont care.
black03rcsb
Sep 1, 2015 10:17 AM
MattOKC
Aug 18, 2015 11:30 AM
GM1697
Jul 14, 2015 01:21 PM
rojeho
Jul 12, 2015 06:10 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
