Valve Spring Life
Old Feb 12, 2022 | 12:58 PM
blsnelling's Avatar
Pull a couple and check them.
Just for the record PAC 1218 spring specs:
  • Install Height - 1.800"
  • Load at Installed Height - 130#
  • Spring Open Height - 1.200"
  • Spring Open Load - 318#
Something like this should work in a vise.
Mini Spring Tester Mini Spring Tester
OR
0-700 Gauge 0-700 Gauge
Spring Height Micrometer Spring Height Micrometer
Old Feb 12, 2022 | 01:17 PM
MikeGyver's Avatar
Originally Posted by RedXray
Depends when the breakage occurs...
Mine broke at 70 mph cruising, so about 2200 rpm. Destroyed the engine.
https://www.performancetrucks.net/fo...prings-556713/
Old Feb 12, 2022 | 01:50 PM
arthursc2's Avatar
that sucked hard man. That still hurts to read 😖
Old Feb 12, 2022 | 08:18 PM
MikeGyver's Avatar
Thanks. Now quit using single valve springs.
Old Feb 14, 2022 | 12:53 AM
1FastBrick's Avatar
Custm2500's Rude Friend
You should ask Dantheman1540 about Pac 1218 singles in his Tahoe. Although it didn't cost him a motor like MikeGyver...
https://www.performancetrucks.net/fo...6/#post5488143
Old Feb 14, 2022 | 06:44 AM
dantheman1540's Avatar
I got very lucky, it died at idle OMW to work. The valve bounced 4 or 5 times off the piston before it lodged itself in the head. Not using singles anymore!
Old Feb 14, 2022 | 06:33 PM
Richardman1992's Avatar
I’ve got roughly 108k miles on my blue ls6 springs with my baby comp 212/218 cam. *knock on wood
riverhawk
Aug 21, 2017 05:04 AM
slowdenali
Mar 7, 2010 05:14 PM
nonnieselman
Oct 14, 2009 08:55 PM
sharpshooter
Mar 11, 2008 07:02 PM
onequick5.3
Sep 14, 2004 04:57 PM
