Updated Project Section (Pics)
Old Nov 8, 2004 | 06:18 PM
Speed Engineering's Avatar
Former Vendor
Default Updated Project Section (Pics)
We finished up a coupple of projects in the shop thought you guys might want to take a look.
Link to Project Section
Old Nov 8, 2004 | 07:58 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Nice job! Any details as far as dyno or track times out of the 408 N20 regular cab truck?
Old Nov 8, 2004 | 11:23 PM
Former Vendor
That was about a year and a half ago. The truck is now stock and used as a daily driver. However it has a new setup going in within the year. Smaller motor (383) but a better combo of parts and power adder.
Old Nov 8, 2004 | 11:26 PM
2toneblown's Avatar
I wana know more about the 408 with the F1
Old Nov 8, 2004 | 11:28 PM
XLR8NSS's Avatar
Adkoonerstrator
408Stepside01 - Is that you?
Old Nov 9, 2004 | 12:49 AM
GoldenVelvet's Avatar
Yup. Same guy.
Old Nov 9, 2004 | 10:22 AM
Former Vendor
Yes it is. Got my own shop now. If you guys need any parts just let me know. I will get you guys the best deal i can. The truck with the F1 has got a tone of power. We just cant keep the heads down on the dam thing. We are going with a little bit lower compression heads. Should be some where around the 8-8.5:1 compression with these new heads.
Havent talked to you guys for a while. I have been busy in the shop. I am going to be on here a lot more now though that winter is comming up.
Sean
Old Nov 9, 2004 | 11:13 AM
BigKID's Avatar
I was wondering what the deal with the blue head gaskets was. Is is some sort of coating to help the gasket stay together under the high cylinder pressures? Have yall though about oringing it?
Old Nov 9, 2004 | 11:38 AM
2toneblown's Avatar
what heat gaskets are yall using?
Old Nov 9, 2004 | 12:50 PM
Former Vendor
The motor is o-ringed. With counter sunk grooves in the heads aswell. We are using copper head gaskets. The coating that you see is called Hylomar. It's just like Copper Coat, but with a lot higher temp rating. The stuff works great. We use it on all of our setups with copper gaskets.
blowngmc
32
Oct 12, 2017 11:59 AM
6.0l RST
Nov 23, 2015 11:30 AM
rumblebox
Oct 29, 2015 10:35 AM
Pontiac Derek
Sep 18, 2015 09:02 AM
600 horses
Sep 10, 2015 11:01 AM
