underdrive pulleys good or bad
Old Feb 28, 2012 | 11:43 PM
matt92extcab's Avatar
Default underdrive pulleys good or bad
some people say there good some say no what is your opinion
Old Feb 28, 2012 | 11:47 PM
grey matter 04's Avatar
13 Second Truck Club
good....improves throttle response and usually good for .1 at the track
Old Feb 28, 2012 | 11:50 PM
Atomic's Avatar
I have a gauge for that
For NA, probably good. If you run a blower/turbo/nitrous then dont bother....especially with a blower.
Old Feb 29, 2012 | 01:20 AM
zero2sixT's Avatar
If you're doing a cam swap, might as well throw on an under-drive pulley on the crank. I wouldn't mess with the alternator pulley.
Old Feb 29, 2012 | 04:52 PM
I just got my UD pulley in the mail today. I will post my impression/results when I get it installed this weekend.
Old Feb 29, 2012 | 05:10 PM
tylertxss's Avatar
What kind of pulley installer do yall use to install those with?
Old Feb 29, 2012 | 05:48 PM
colekill's Avatar
KickinAssAndTakinNames
I have had mine for years now, and love it. just dont let it idle for two long in traffic, it might start to overheat. when i was evacuating for hurricane Ike it was standstill traffic for hours, I had some issues.
Old Mar 3, 2012 | 08:47 AM
I installed my powerbond ud pulley last night after work and have to say that I am pleasantly suprised at my results...feels like I gained a minor amount of power/torque everywhere. At this point I would call this a worthwhile mod. I will do a few gtech runs to see what I have gained within a week or so and also share my air intake results (MIT -vs- vararam)
I can't remember exactly where I got the write up that I printed out before the install, but it made the job sound tough. I only took about 1 to 1.5 hrs completing the task by myself with about half of the time fighting around with my 3 jaw puller (keeping all 3 arms in the correct position). I used my old crank pulley bolt (with a small dimple drilled in the center) to push against with my 3 jaw craftsman puller....when that bottomed out...I used a 3/8" socket extension. I used a long screwdriver and wedged it through a hole in the flywheel to loosen my original crank bolt. I bought the SDPC install tool to press on the pulley and installed an old style tensioner on my AC belt. The new belts went on easier than I had experienced with any other vehicle...just make sure that you draw a "map" ahead of time so that you know how to route the belts.
There seem to be no compromises with this mod at this point except a slightly lighter wallet. You wouldn't be here reading this thread if you didn't want one so go ahead and order one. I got great service from sdpc parts.
Old Mar 3, 2012 | 12:31 PM
darnie's Avatar
I been thinking about doing this as well.... i have a 04 gmc sierra ext cab 4x4 with the 5.3 im just not sure what one to get and also heard your saposto change the alt pulley as well?
Old Mar 3, 2012 | 03:04 PM
Ferocity02's Avatar
I have a PowerBond pulley and love it, the biggest gain was how much faster the engine revs, and its comforting to know everything under there is spinning a little slower perhaps prolonging their life. I did put in a 145A alternator at the same time though. Didn't notice any change to the cooling or power steering.
