underdrive pulley ?'s
Old Jan 19, 2010 | 09:47 PM
jow02327's Avatar
Default underdrive pulley ?'s
I'm sorry if this is in the wrong section...
I am looking at purchasing an underdrive pulley and have found that some come with the overdriven alternator pulley and some don't. So my question is do i need the overdriven alt. pulley or will i be fine without it? Thanks in advance.
Jed
Old Jan 20, 2010 | 11:05 AM
Mrgoodwrench3's Avatar
It is best to run the alternator pulley to maintain the correct charging system voltage. Check out these pulleys.
http://www.summitracing.com/parts/ASP-549984/?rtype=10
Old Jan 20, 2010 | 02:01 PM
8.1 HD's Avatar
I run the Powerbond udp on my '07 Tahoe with no overdrive alt. pulley. I have had zero problems with the charging system at all.
Old Jan 21, 2010 | 06:01 AM
JJB's Avatar
JJB
X2 Same here
Old Jan 21, 2010 | 09:15 AM
LS1TRUCKGUY's Avatar
i had no issues until i installed e-fans. the initial startup of the fans would make the voltage dip bad. the overdrive alt. pulley almost fixed it. it just barely dips now
i have the asp pulleys, btw
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
