underdrive pulley - adverse effect?
Old Jul 26, 2004 | 10:26 PM
one03sierra's Avatar
Formerly one92rs
Talking
i have often wondered about that myself. i figure as long as they are balanced we will be alright. i still might remove mine just to see.
Old Jul 26, 2004 | 10:55 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Make up your mind already!
Old Jul 26, 2004 | 11:26 PM
Flyer's Avatar
I could see that happening. The pulley is also the harmonic balancer which is used to even out the pulses from the piston firing. In a Honda it would be more brutal because it's only 4 cylinders per revolution, where these motors are have twice the pulses so it's a whole lot smoother. The flex-plate/converter or flywheel/clutch is suppose to keep the balance on the back of the engine as well.
It makes perfect sense, but for the fact the v8 would be twice as smooth with the pulses per rev ... I don't think it would be as much an issue with the v8's.
Old Jul 28, 2004 | 06:53 AM
Originally Posted by Tiburon
I was a little skeptic before put mine on. I did notice a nice difference right away. Along with that nice difference I also noticed drop in voltage when I am sitting in trafic. Here are some dyno results just from the crank pulley.
https://ls1tech.com/forums/showthrea...ght=asp+pulley
Is that with e-fans or wit hthe stock fan? With e-fans you would get less of a gain because that drag is already gone.
Old Jul 30, 2004 | 09:51 AM
Another_User's Avatar
I think the only real drag is coming from the power steering pulley. They even sell an underdrive power steering pulley...probably better than the short belt mod.
________
Blonde Cams
Old Jul 30, 2004 | 12:26 PM
Flyer's Avatar
THe water pump takes some power too. As well as the altenator.
Vortec350ss
Jan 12, 2016 10:36 PM
Avalanche2002
Nov 30, 2015 07:31 AM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
