Two performance things, need opnions.
Old Jul 14, 2006 | 04:49 PM
inmywhitez's Avatar
Default Two performance things, need opnions.
what do yall think about underdrive pullies and a 160 degree thermostat? Good ideas for boltons? i am running out of options now. thanks- Allan
Old Jul 14, 2006 | 05:06 PM
BradS's Avatar
Look at the BB mod in the southern section. I have it done to my truck (thats my waterpump in the how to) and it brought my temps down by about 15 - 20 degrees. it was 110 yesterday by my truck thermometer and I was runnin at about 180/ 185ish
Old Jul 14, 2006 | 07:25 PM
Post
160* stat, not worth it unless you have FI. You lose 1 mpg as well. Don't ask why, you just do. If you just have to change your t-stat, use a 180* stat. Either which one you chose, you won't gain power from it.
The biggest advantage is cooler tranny temps. Which helps prolong its life.
The power pulley's, well....if you have the money to spare, any extra hp or tq gain is always good from a mod. The pulleys might get you 3-5hp. The disadvantage is, low amperage from alternator at idle. That usually kills your battery pretty fast. If you decide to use one, buy one that is just the crank pulleyand maybe water pump pulley.
Good luck!
Jim
Choda
Jan 22, 2026 02:03 PM
Oobray
Jun 13, 2022 03:38 AM
Raggedz71
Jul 29, 2016 10:20 AM
mrhino
Aug 7, 2015 10:01 AM
cbhedrick
Jul 20, 2015 10:12 PM
