Trans rebuild?...NineBall
Old Jun 27, 2002 | 09:07 AM
Default Trans rebuild?...NineBall
Tony, what is the procedure for building this tranny to hold up? Where exactly does a window switch go? I do listen i was just floored about the truck making that power i was expecting more along the lines of 380hp. I've already done some work like the transgo recalibration to the tranny and pump. I have not put in a converter yet though. I'm wanting to get a motor finished first.
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
________
Voyeur ****
Old Jun 27, 2002 | 09:24 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Trans rebuild?...NineBall
We have a local shop that rebuilds them for higher horsepower/torque applications. Century Transmissions, formerly PMAC. Mike has alot of experience with those 4L60Es by now, you are looking to spend about $2K in most cases.
The window switch has an rpm-sensing input wire that you tap into your PCM on the tach signal wire. You set the on/off rpm limits with plug-in rpm pills like a shift lite. Use 3K rpm to turn the nitrous on, and have it shut off about 200-300 rpm before wherever you have your rev limiter set at.
Tony
Old Jun 27, 2002 | 09:43 AM
Mr Powell's Avatar
8 Second Club
If its the same people MTI recommended my friend. I would go there. They did awesome work on my buddies tranny.
Old Jun 27, 2002 | 10:05 AM
oxidizr's Avatar
Moderator / Sponsor
The Transgo "reprogramming kit" is complete and an excellent kit but some of the mechanical components just can't take the elivated stress.
There are a few ways to go to increase the strength of the tranny. One is a 200R4 internals conversion (I think this is what Yank does for their 4L70) or more recently the aftermarket has provided much more 4L60E specific replacment parts. These are some replacement parts I've been collecting for my trans rebuild (thanks Ken):
Thunderbolt servo has 35% more holding power than the good ol' Corvette servo.
High performance overdrive billet servo. Has 50% more holding power than the stock overdrive servomakign extra firm 3-4s. Good for towing in overdrive or vehicles geared to pass through the traps in OD.
29 element Borg Warner forward input sprag with double cage construction.
Raybestos Pro Series High Energy Kevlar Bands.
Raybestos Blue Plate Special 6 count 3-4 clutch set.
Extreme Duty front and rear planets with 5 (2002 GM type) pinion gears which are 25% stronger than the old type. Get the hardened outside planet ring gears while your att it too.
Extreme Duty reaction carrier shaft. Has an aftermarket shell and allows the entire rebuild to take place without thrust washers.
Hardened input shaft and drum assembly plus a hardened reaction shell and bearing. They are rated to withstand over 600 ft-lbs.
Replace the OEM plastic thrust washer with a roller thrust bearing to reduce heat but you are going to need a specially machined and hardened rear planetary inner race to complete the assembly.
Richard
Old Jul 15, 2002 | 09:25 PM
XLR8NSS's Avatar
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by oxidizr:
<strong>The Transgo "reprogramming kit" is complete and an excellent kit but some of the mechanical components just can't take the elivated stress.
Richard</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Richard
What do you think would hold up better to a superstroker?
The 200R4 conversion or the trans your building.
Also where can I find these parts?
Do you think it would be easier to just put in a 4L80E with a shift kit?
I'm going to be real interested in a transmissions here very shortly. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks
John
Old Jul 15, 2002 | 10:00 PM
oxidizr's Avatar
Moderator / Sponsor
The 4L80E would be nice but adds lots of weight and presents compatability issues with the ECM. Not impossible to fix but some minor obstacles.
Richard
Old Jul 16, 2002 | 04:37 PM
GREGGO's Avatar
Hyde, FYI, the rpm wire on the ECM is the white #10 wire. I have and MSD window switch.
Greg
Old Jul 16, 2002 | 05:06 PM
bdubb's Avatar
Ross House is still around and has been doing some 4l60E's lately also.
He can be contacted at 713-690-3673. May have to leave a message with someone though.
Old Jul 16, 2002 | 05:16 PM
What the hell are you talking about?
________
XXX STREAMING
ferrellrooster
Mar 6, 2025 03:22 PM
Raggedz71
Jul 29, 2016 10:20 AM
tito green
Aug 14, 2015 06:01 PM
SleeperGMC
Jul 29, 2015 10:22 AM
zaathur151
Jul 6, 2015 10:57 PM
