Trans Issue
Old Apr 16, 2009 | 09:48 AM
shandy294's Avatar
Default Trans Issue
On the way to work today it slipped for a moment and then "caught" as I left from a light under light acceleration.
Is it possible to get something like this as an occasional abnormality or is always a sign of impending failure?
It only has 47K and has light use for the most part.
I know I could've posted in another section but this one has more activity.
Old Apr 16, 2009 | 11:38 AM
shandy294's Avatar
N-e-1 ?
Old Apr 16, 2009 | 11:40 AM
dlt76028's Avatar
change the filter and fluid and pray
Old Apr 16, 2009 | 12:11 PM
chevrolet all the way's Avatar
DO NOT put any addetives in. if anything do as dlt76028 said and change fluid/filter. look in the pan for any excesive clutch material or metal. theres a magnet on the pan which helps on that. also clean the pan as much as possible while its out to save a little trash running through the filter. if you see a lot of contamination just clean change and pray...
Old Apr 16, 2009 | 12:14 PM
lucky77's Avatar
Banned
if it's shifting .. its still ok. . when it dont move . . then u have a problem
Old Apr 16, 2009 | 12:15 PM
00Silv4.8's Avatar
I got a trans for sale if you want?
But like they said that's not a good sign at all, I'm gonna be straight with you, when mine acted up it lost reverse and drive when I parked it that day
Old Apr 16, 2009 | 12:53 PM
shandy294's Avatar
Thanks for the replies. The pan holds about 4 qts,right? What about having it power flushed at a good place?
I'm gonna be really pissed if it's on its way out at 47K. I check the fluid often for level and color.
If it needs a new unit,I'll sell the truck after that.
It has a 125k limited power train warranty from the dealer.
Old Apr 16, 2009 | 01:05 PM
dlt76028's Avatar
yea about 4qts. dont flush it, just change the fluid
Old Apr 16, 2009 | 01:34 PM
D_reks{5.3}'s Avatar
Ive seen em take a **** in stock v6s with less mileage...its the luck of the draw.
Choda
Jan 22, 2026 02:03 PM
GMCtrk
Jul 17, 2015 06:39 PM
bsn1989
Jul 16, 2015 08:20 AM
lxcoupe
Jul 14, 2015 10:14 PM
