Tranny Question
Old Jan 12, 2004 | 05:39 PM
12 Second Club
Question Tranny Question
will a 4L80 if it will bolt right up and hook up to my stock z-71? what is it stock, a 4L60 or 4L65?... mine took a **** on me from the way home from work thanks, matt
Old Jan 12, 2004 | 06:52 PM
4L80E transmission is not a straight bolt-in.You need a transmission,a new converter,a crank spacer,a new flywheel,a modified crossmember,a harness adapter and programming from Speartech.It's doable but not cheap.
Old Jan 12, 2004 | 10:16 PM
12 Second Club
ok thanks, scratch that idea.
Old Jan 13, 2004 | 08:09 AM
4L60E was stock. There are a lot of parts and builders out there that can make it work for you within reason.
Old Jan 13, 2004 | 09:15 AM
BigTex's Avatar
FrankSS - Your sig says you have an entire LS1 drivetrain for sale. Is that a M6 or A4? If you have an A4, you could have a shop swap the good trans internals to the 4wd cast and output shaft of your truck. The transmissions are the same other than the shaft and tail housing.
blownss27
Aug 14, 2020 08:27 AM
Alco
Sep 4, 2015 04:08 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
abey15
Jul 13, 2015 02:20 PM
