Tranny Question
12 Second Club
will a 4L80 if it will bolt right up and hook up to my stock z-71? what is it stock, a 4L60 or 4L65?... mine took a **** on me from the way home from work
thanks, matt
thanks, matt
4L80E transmission is not a straight bolt-in.You need a transmission,a new converter,a crank spacer,a new flywheel,a modified crossmember,a harness adapter and programming from Speartech.It's doable but not cheap.
FrankSS - Your sig says you have an entire LS1 drivetrain for sale. Is that a M6 or A4? If you have an A4, you could have a shop swap the good trans internals to the 4wd cast and output shaft of your truck. The transmissions are the same other than the shaft and tail housing.
