tr224 vs tsp 224r vs tsp 228r
Old Dec 27, 2008 | 11:20 PM
  #21
GMCtrk's Avatar
Nice! Let's be honest here though, you have more compression and better heads. So I'd expect you to make 10-20 more hp. TSP's dyno testing showed that the 228 made 6 rwhp more than the 224 with little to no sacrifice in driveability.
I'm going to use the SDPC springs and TSP pushrods, LS2 timing chain, and will reuse my stock oil pump.
Old Dec 27, 2008 | 11:29 PM
  #22
fastrt's Avatar
11 Second Truck Club
sounds like that will be a nice setup. I vote stall, even though you don't want one. those springs are pac springs or good 918's so I hear.
Old Dec 27, 2008 | 11:33 PM
  #23
GMCtrk's Avatar
I look at it this way, I can always add a stall later down the road. This truck had a 4.8L and 3.42 gears for 143k miles, whatever I do it's not going to be worse of a pig than that! The way I drive doesn't really lend itself towards a stall anyways. I like a very stiff throttle and usually drive like an old fart most of the time. How else can you explain the fact that my stock 60e is still working perfectly?
Old Dec 27, 2008 | 11:39 PM
  #24
fastrt's Avatar
that is true! eitherway it will sound great. what lsa ? any advance?
Old Dec 27, 2008 | 11:43 PM
  #25
GMCtrk's Avatar
112 LSA. Not sure on the advance. If it's +0 I'll consider advancing the cam 4 degrees when it's installed.
This should put me solidly into the 13s with the addition of the 4.10s
Old Dec 27, 2008 | 11:52 PM
  #26
Thechevyman122's Avatar
sorry to threadack, but i hate starting cam threads.
What exactly is advancing? what advantages /disadvantages is caused by this, and more importantly how do you do it when you install a cam.
I also just bought a tr224, should be going in by the end of february with some cut outs, and a good tune.
Old Dec 27, 2008 | 11:58 PM
  #27
GMCtrk's Avatar
Advancing the cam brings the powerband down.
Old Dec 28, 2008 | 12:02 AM
  #28
NateZQ8's Avatar
With your 6.0........I would go with a 224 with XE-R type lobes and a 112 LSA. It will get you lots of chop and a nice TQ curve
Old Dec 28, 2008 | 12:05 AM
  #29
GMCtrk's Avatar
I went with the 228r
I just ended up buying the first one available at a good price. There really shouldn't be much difference between any of the 3 cams when it comes down to it I believe.
Old Dec 28, 2008 | 10:25 AM
  #30
i plan on keeping my stock 3.73's and wont be able to afford a tc for awhile. Advancing the cam sounds like agood idea for me..how many degrees should i advance mine when i install it?
Texas5.3_1251
Mar 5, 2016 08:10 PM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
jtphelps289
Sep 29, 2015 12:00 PM
nickrench3
Sep 17, 2015 08:48 AM
