Tick Performance exaggerated performance claims
Old Oct 31, 2021 | 09:39 PM
  #91
Fast355's Avatar
The tri-ys scavenge my healthy 383 very well. See gms/cyl reading over 1.00 across a fairly wide RPM range. 360 gms/sec airflow at 4,750 rpm and 390 gms/sec at only 5,200. 383 is moving a ton of air at fairly low rpm.
Old Nov 1, 2021 | 06:53 AM
  #92
arthursc2's Avatar
Originally Posted by 68Formula
For what vehicle exactly? These come with the y-pipe for a truck. Once you add the y-pipe to the TSPs they're very close.
GMT800 truck. I built my own Y, so I spent time instead of money. It's been 5yrs, but I spent $440 on my 1 7/8 from TSP
Old Dec 9, 2021 | 06:30 PM
  #93
Hardcourt's Avatar
Hi folks I'm pulling this cam out and starting over. RonSSNova, bless his kind soul, tried his darndest to tune it and get it to stop surging, but the surge continues. So, I'm now humbly looking for your input on a new cam choice. As a reminder, this is a 4.8 with 706 heads, cold air intake, stock exhaust manifolds and true dual exhaust with X pipe and flowmaster 40-series. I'd like to retain the Tick dual valve springs that are in the truck. This is a daily driver and I just want it to have more low end grunt, right off idle. I do Not Care about top end gains, I spend my time from idle to 3k (usually closer to 2-2500k). I also don't want to have to make any other changes such as torque converter, long tube headers, or any other exhaust changes. With that said, the cams I'm considering are:
BTR Truck Cam Stage 1 V2. SPECS: 206/212 .553/.553 112+0
https://briantooleyracing.com/btr-ca...r30612120.html
BTR Torque cam SPECS: 202/202 .511/.511 111+1
https://briantooleyracing.com/btr-ca...-30202112.html
I would greatly appreciate your input on which of these two you'd suggest, and why. Or what other cams you might suggest, given my goals. Thank you!
Old Dec 9, 2021 | 06:45 PM
  #94
FFDP's Avatar
This would also be a good camshaft, tons and ton of people use this one.
https://briantooleyracing.com/btr-ca...r31218110.html
Old Dec 9, 2021 | 11:00 PM
  #95
RDF1's Avatar
DuNnO
5 Year Member
Im with FFDP. This is a good all around camshaft and is very easy to tune.
Old Dec 10, 2021 | 09:35 AM
  #96
Jeff71's Avatar
5 Year Member
You should be fine with either of your listed choices. Given your stated goals the torque cam would probably get the nod.
Old Dec 10, 2021 | 09:55 AM
  #97
MikeGyver's Avatar
Unless you have a custom cam ground, any performance cam will raise the peak torque rpm and reduce the power in the range that you want. Check the dynograph in FFDP's link, they don't show the stock cam's performance in the lower rpm, because it's probably better than what they are selling. You need either a stock cam, a custom ground cam, more displacement, or boost to satisfy your wants.
Old Dec 10, 2021 | 10:57 AM
  #98
TXsilverado's Avatar
put the stock cam back in and buy gears or a blower. my 2c.
Old Dec 13, 2021 | 01:34 PM
  #99
Hardcourt's Avatar
Thanks for the input so far. Between the BTR Stage I and the BTR Torque cam, which would deliver better fuel economy? (Not my number one concern, but it’s a factor)
Old Dec 13, 2021 | 01:53 PM
  #100
RDF1's Avatar
DuNnO
5 Year Member
Doubt there is going to be a difference in Fuel Mileage between those to cams.
shakenfake
Nov 22, 2019 06:28 AM
Denali Dude
11
Feb 7, 2009 07:05 AM
phatboy
Sep 15, 2006 07:05 PM
GREENMILE
Mar 13, 2006 09:48 AM
Mr. Sandog
19
Nov 21, 2004 11:47 AM
