which throttle body will work with 03 gmc adding L92 heads/intake
Old Oct 16, 2011 | 04:43 PM
Default which throttle body will work with 03 gmc adding L92 heads/intake
So in terms of adding L92 heads/intake, which throttle body would bolt and plug right up? My stock 78mm dbw would be too small so looking for something 87-90 range. Could I use the tbss throttle body? Or a newer (08+) truck throttle body? Just want to make sure it will plug right up to my 03 engine harness and be easy to tune. Thanks
Old Oct 16, 2011 | 04:51 PM
black04's Avatar
You will need a dr x harness
Old Oct 16, 2011 | 05:08 PM
grey matter 04's Avatar
13 Second Truck Club
I hope that 03 gmc has a 6.0 or bigger
L92 heads need a 4.00 inch bore or bigger
Old Oct 16, 2011 | 11:47 PM
It has a 6.0 dont worry.
Thanks for the help, no way I would have found that by searching. Found a post here that linked me to torquerush.com. where he sells the harness.
But...they are $225. Are you kidding me? So is there no other option?
Old Oct 16, 2011 | 11:57 PM
1Bear's Avatar
The only other option is to use a simple adapter harness and an ’02 style TAC Module. It will work, but it’s not all it’s cracked up to be either, as it will not allow 100% throttle blade opening and is the driving factor to everyone using the X-Link by Torquerush.
Old Oct 17, 2011 | 12:03 AM
black04's Avatar
You could also make an adapter for the intake manifold to use your 3 bolt stock 78mm tb
Old Oct 17, 2011 | 01:44 AM
Do those adapters exist?
Is the dr. x harness just plug and play or do I have to splice any wires in the engine harness? Does it work flawlessly or are there bugs?
Old Oct 17, 2011 | 01:58 AM
And what size throttle body came stock on the L92 intake? Seems like it was a 90mm similar to the tbss one. If so I would also need the same dr X harness for that throttle body as well?
Old Oct 17, 2011 | 02:05 AM
mhotrodscooter's Avatar
X-link is plug & play. 87mm on trucks & 90mm on the cars, not sure about the tbss
Old Oct 17, 2011 | 03:46 AM
bai78's Avatar
Originally Posted by 99bluefirebird
Do those adapters exist?...
You could use one of theses...
OHsixLS3
Dec 27, 2016 09:30 AM
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
