which throttle body will work with 03 gmc adding L92 heads/intake
So in terms of adding L92 heads/intake, which throttle body would bolt and plug right up? My stock 78mm dbw would be too small so looking for something 87-90 range. Could I use the tbss throttle body? Or a newer (08+) truck throttle body? Just want to make sure it will plug right up to my 03 engine harness and be easy to tune. Thanks
It has a 6.0 dont worry.
Thanks for the help, no way I would have found that by searching. Found a post here that linked me to torquerush.com. where he sells the harness.
But...they are $225. Are you kidding me? So is there no other option?
The only other option is to use a simple adapter harness and an ’02 style TAC Module. It will work, but it’s not all it’s cracked up to be either, as it will not allow 100% throttle blade opening and is the driving factor to everyone using the X-Link by Torquerush.
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
