Throttle body coolant hose????
Old Aug 15, 2010 | 10:15 AM
onebad03's Avatar
so everything is good? its ok to use this one?
Old Aug 15, 2010 | 10:59 AM
Spoolin's Avatar
GFYS and STFU
If Kyle blocked off his cross-over then I guess it's ok but I'd be hesitant to do it personally.
Old Aug 15, 2010 | 11:54 AM
Camaro Zach's Avatar
I wouldn't block it off unless you vent all of the air out of the heads before it is permanently blocked.
The hose is there to help vent air bubbles out of the heads which can lead to hot spots. Older gm motors and the 4.3 v6 do not require the hose because the upper radiator hose is in the intake manifold (highest point at which the coolant flows through the engine.) In the LS motors all of the coolant flows through the water pump which is much lower than the heads. Therefore air can be trapped in the top of the heads because air is lighter than water.
Old Aug 15, 2010 | 12:24 PM
onebad03's Avatar
it still crosses over but it would be blocked from the radiator.
Old Aug 15, 2010 | 12:33 PM
charcold-bowtie's Avatar
Originally Posted by kbracing96
My stock one wouldn't fit when I put the TVS on for the compound setup, so I clipped the line and welded it shut. Been running with no head coolant port flow there for a year and a half now.
Thats good to know, mine are currently all blocked with plugs. All 4 corners
lucas287
31
Jan 12, 2021 06:18 AM
blownss27
Aug 14, 2020 08:27 AM
6.0l RST
Nov 23, 2015 11:30 AM
Gadgetized
Jul 7, 2015 04:40 PM
