Throttle body coolant hose????
Old Aug 14, 2010 | 07:28 PM
onebad03's Avatar
Default Throttle body coolant hose????
I was getting ready to put in my 34" radiator and was checking everything over to make sure I have what I need before I start. Well I noticed there is no coolant port between the transmission cooler lines like on mine. Its the small one that runs from the radiator through the TB and into the driverside head. Ive already done the bypass on the TB so is it ok to cap the port off on the head? This is on an 04' silverado BTW. Thanks for any help.
Old Aug 14, 2010 | 08:18 PM
kbracing96's Avatar
My stock one wouldn't fit when I put the TVS on for the compound setup, so I clipped the line and welded it shut. Been running with no head coolant port flow there for a year and a half now.
Old Aug 14, 2010 | 08:28 PM
Atomic's Avatar
I have a gauge for that
Are we talking about the coolant crossover pipe thing? I was under the impression that is to relieve excessive pressure build up from coolant boiling in the head....
Old Aug 14, 2010 | 08:45 PM
onebad03's Avatar
cool man thanks. i guess ill just get a cap and clamp it on.
not sure, its at the front of the drivers side head and the hose is clamped onto a nipple.
Old Aug 14, 2010 | 09:05 PM
Atomic's Avatar
Yea, and its connected to a block with a tube going to the passenger side head?
Old Aug 14, 2010 | 10:04 PM
onebad03's Avatar
yeah it goes over to the passanger side, i didnt notice it crossed over before.
Old Aug 14, 2010 | 10:09 PM
Atomic's Avatar
Yea...odd since my 34" rad has a port for that...
Old Aug 15, 2010 | 12:48 AM
brent5631's Avatar
I think the radiators from v-6 trucks don't have that nipple.
Old Aug 15, 2010 | 09:57 AM
onebad03's Avatar
it could be?? because i went to put it in last night and the transmission cooler lines are different threads, so i had to put my factory one back in and ill get some fittings that will work later on when im ready for the fans to go in.
Old Aug 15, 2010 | 10:03 AM
00ChevyScott's Avatar
Wearin' da big hat
That's correct, Luke03 had that same problem and his was from a V6 truck.
