Are these good efans?
Old Jan 27, 2010 | 05:36 PM
HDSIERRA's Avatar
Default Are these good efans?
Got two of these 16" efans and 34" rad, Do u think the fans will pull to much watts for the stock(105 amp alt)? Also have two pin blackbear harness on the way.
amps=watts divided by volts
18.333=220 divided by 12 -each
http://vi.ebaydesc.com/ebaymotors/ws...ller=skipwhite
Old Jan 27, 2010 | 05:58 PM
HDSIERRA's Avatar
Any one know the amps the 05+ or ls1 pull?
Old Jan 27, 2010 | 06:10 PM
Z'06's Avatar
Not sure, but my '06 came from the factory with a 160-amp alternator (KW1).
Old Jan 27, 2010 | 07:00 PM
HDSIERRA's Avatar
Anybody?
Old Jan 27, 2010 | 08:19 PM
Coban's Avatar
You'll be fine. Those fans "seem" like they are lighter duty... The 05-06 fans are some heavy duty units and I run them with the stock 105 amp alternator. No issues. The 2-pin harness was a most excellent move.
From your first post, did you buy that 34" radiator? A 2500 should come stock with it.
Old Jan 27, 2010 | 08:31 PM
HDSIERRA's Avatar
Came with 34". Done some more research myself and will go with the 05! I just installed Pace setter LT and needing a tune. Wanted to go ahead have it set up for the efans.
Old Jan 28, 2010 | 09:34 AM
JJB's Avatar
JJB
if you measure 34" from barell to barell that is the smaller radiator ...you need to measure from inside fin to inside fin
Old Jan 28, 2010 | 09:58 AM
HDSIERRA's Avatar
Yea i know. 2500 stock have 34" besides i measured it before i bought them. I am going to use them for little while. Then i'll get 05+ efans. Then use these on the RCSB i plan on building!
DrX
Aug 19, 2015 04:45 PM
creekrat
Aug 2, 2015 01:27 AM
ullose272
Jul 19, 2015 04:14 PM
01sierraon22s
Jul 8, 2015 11:26 AM
