How does the efan conversion work
Old Jul 19, 2015 | 08:35 AM
ullose272's Avatar
Default How does the efan conversion work
So im trying to figure out my over heating. Ive got a 2001 2500hd ive converted to efans the nelson performance harness. Does high speed only come on if i have the a/c on? Looks like it will only come on if a/c is on and low speed fan is on? Because i just have the one pcm trigger. And will never go high speed only because of temp?
Old Jul 19, 2015 | 09:20 AM
ullose272's Avatar
Hmm after some reading maybe i should have gotten the later 2 pin harness instead of the a/c wire harness and flashed the later OS? I just want to make sure both fans will come on high
Old Jul 19, 2015 | 10:03 AM
GMCtrk's Avatar
Return the 1 pin harness and get 2 pin harness. Better yet, get an OEM harness.
Old Jul 19, 2015 | 11:44 AM
03sierraslt's Avatar
Agreed, get a OEM harness or the two pin at a min.
Old Jul 19, 2015 | 12:34 PM
ullose272's Avatar
how hard would it be for me to modify this harness? is it the same except the a/c wire gets hooked to hot and the ground for that relay is now for second pcm pin?
Old Jul 19, 2015 | 01:29 PM
ullose272's Avatar
or maybe i can just make it high speed or not, and just skip the low?
Old Jul 19, 2015 | 04:14 PM
ezdaar's Avatar
Hayden Automotive 3653 Economy Adjustable Thermostatic Fan Control https://www.amazon.com/dp/B000C39C6I..._4lbRvbXXJ26N1
Use this on your high speed AC trigger.
Oobray
Jun 13, 2022 03:38 AM
creekrat
Aug 2, 2015 01:27 AM
01sierraon22s
Jul 8, 2015 11:26 AM
mrgrim
Jul 8, 2015 08:12 AM
