1998 spark plugs
hi guys i am looking at doing tune up plugs and wires and cap and rotor my question is what are some good options for spark plugs? let me tell you about the truck i have a 1998 K2500 5.7L it is not a dayley driver i typically only use the truck for pulling trailers or when i go up north with that is there a better plug fot towing than the stock acdelco i beleve i have NGK TR55 in the truck know anny sugestions on what plugs i should use would be great thanks
I run the AC Delco "Professional Platinum" Plugs in mine. I changed them out when I did my headers at around 96000 miles. They're supposed give you 100,000 miles of use before needing replacement. They've been doing good so far.
Your best bet is the stock ACDelco's or comparable NGK. If you're looking for an extended interval between spark plug changes, go for either platinum or iridium. Supposedly, iridium plugs are supposed to be better at not leaving as much carbon behind, but I don't know if that's fact or just marketing.
