Thermostat
Old May 11, 2004 | 08:27 AM
BLUE'03's Avatar
Question Thermostat
I DON'T PLAN ON A E-FAN UPGRADE UNTIL AN ENGINE SWAP.IF I JUST SWITCH TO A 160* T-STAT WOULD IT MAKE A NOTICABLE DIFF? WOULD I HAVE TO DO ANYTHING ELSE?(PROGRAMMING). BY THE WAY THIS FORUM HAS BEEN VERY HELPFUL ON ALOT OF THINGS,YOU GUYS RULE
Old May 11, 2004 | 09:48 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Go for it, it's a an easy swap and you can use it with the other engine.
It'll keep your engine cooler and no need for a tune.
allen
Old May 11, 2004 | 11:17 AM
raisinkane's Avatar
Default Thermostat
allen
Won't the colder temperature tell the computer the engine is not up to temp. yet and continue with excess fuel.?
Old May 11, 2004 | 12:26 PM
vanillagorilla's Avatar
It's an easy mod, and its been pretty effective so far. I just did it last weekend and my truck normally sat close to 210*, now it sits a half a tick above 180*. I put the 160* stat in.
I don't think the computer stays in cold start mode, because the stat is open and circulating coolant throughout. Plus, 180* is a lot warmer than ambient (I hope), which is close to what your coolant is at upon cold start up.
Old May 11, 2004 | 12:51 PM
BLUE'03's Avatar
What Is The Best T-stat To Get? Where To Get And How Much?
Old May 11, 2004 | 02:18 PM
OBXMarine's Avatar
Go with the 160. The 180 didn't make a lick of difference in my temps. I run about 172 degrees now. Hypertech is the only brand I'm aware of. Several of the sponsers have them. Tbyrne and Thunder Racing come to mind.
Old May 11, 2004 | 06:24 PM
TwoFast's Avatar
Go to O'Reilleys. Regular thermostats will be fine. They have regular 160 thermostats for about $3-$5. Don't spend $50 on a hypertech one (you are just paying for the name).
Old May 11, 2004 | 11:16 PM
retsell's Avatar
I was told that hypertech was the only one who made one for the ls1. It is 50 bucks because it comes with a new water neck as well.
Old May 11, 2004 | 11:41 PM
$50 isn't worth it.
Old May 11, 2004 | 11:47 PM
F8L Z71's Avatar
That's how I see it. I have never seen one by anyone else for the LS1s
I'd get the thermo if you plan on doing any serious mods. Lots of HP creates heat and keeping the motor even 10deg cooler on avg. can go a long ways toward thwarting detonation.
