Is TBSS intake worth doing without a upgraded cam?
Old 04-11-2018, 08:58 PM
  #21
FFDP's Avatar
Ahh I know now. That's an early DBW harness from a DBW car.
I forgot the Blue/green is 2003+. So because that is red/blue and DBW it's from like a corvette with DBW. That TAC module box is also an early one and different from the 2003+.
So you're kinda screwed if you want to use the 2004 engine with all those sensors and DBW.
https://www.lsenginediy.com/comparin...i-controllers/
Old 04-11-2018, 09:04 PM
  #22
dry_kill's Avatar
Well ****, this was supposedly from a 2004 escalade
Old 04-12-2018, 07:02 PM
  #23
Fast355's Avatar
Looks like a truck harness to me, but I would need to see the fuse block connector to tell. I have seen DBW 5.3 and 6.0L Suburbans as early as 2001. Also all the 8.1s from 2001 were DBW even in the Express vans. The 2002 Express van I have an 8.1 from used the TAC module pictured and a Vette style throttle body and a 6.5 Diesel GMT400 style pedal.
Just noticed the trans connector looks like something that came with a 4L80E too.
I have a HPT file for a 2001 6.0L/4L80E 3/4 2wd Suburban that came from the factory DBW.
Old 04-12-2018, 07:10 PM
  #24
FFDP's Avatar
Eh, either way it's an early DBW harness that won't work if he has 2004 parts.
Old 04-13-2018, 08:29 AM
  #25
dry_kill's Avatar
Yeah I just picked up another harness yesterday from junkyard. It was out of a 03 suburban, had green/blue pcm so it should work. Now I guess I'll be posting the other harness for sale. Don't know what to sell it as though, the guy from ls1tech reassured me it was from a 2004 escalade
Old 04-13-2018, 05:18 PM
  #26
FFDP's Avatar
You may be able to pull part numbers off the pedal assembly to see what it came from. I believe a early truck uses a different pedal than a corvette just because of the the size of the vehicles.
Old 04-13-2018, 08:33 PM
  #27
Custm2500's Rude Friend
1FastBrick's Avatar
That is not a 2004 harness
It's a 99-02 for drive by wire application. The SUVs and a few trucks had a ride control system that used drive by wire. Everything else was cable driven. I had a customer with a 2000 Tahoe that had that system on it. It's completely different from 03-05 and 06-07 classic drive by wire stuff.
lxcoupe
04-11-2016 05:47 PM
Staggered 02
08-18-2014 11:59 PM
madmaro00
09-13-2011 10:22 PM
12sec.5.3
06-01-2008 07:39 AM
2005rst
09-18-2005 11:09 AM
Quick Reply: Is TBSS intake worth doing without a upgraded cam?
