Is TBSS intake worth doing without a upgraded cam?
#21
Ahh I know now. That's an early DBW harness from a DBW car.
I forgot the Blue/green is 2003+. So because that is red/blue and DBW it's from like a corvette with DBW. That TAC module box is also an early one and different from the 2003+.
So you're kinda screwed if you want to use the 2004 engine with all those sensors and DBW.
https://www.lsenginediy.com/comparin...i-controllers/
#23
Just noticed the trans connector looks like something that came with a 4L80E too.
I have a HPT file for a 2001 6.0L/4L80E 3/4 2wd Suburban that came from the factory DBW.
#25
Yeah I just picked up another harness yesterday from junkyard. It was out of a 03 suburban, had green/blue pcm so it should work. Now I guess I'll be posting the other harness for sale. Don't know what to sell it as though, the guy from ls1tech reassured me it was from a 2004 escalade
#26
You may be able to pull part numbers off the pedal assembly to see what it came from. I believe a early truck uses a different pedal than a corvette just because of the the size of the vehicles.
#27
It's a 99-02 for drive by wire application. The SUVs and a few trucks had a ride control system that used drive by wire. Everything else was cable driven. I had a customer with a 2000 Tahoe that had that system on it. It's completely different from 03-05 and 06-07 classic drive by wire stuff.
lxcoupe
Apr 11, 2016 05:47 PM
