TBSS intake swap on 03 LQ9 6.0
Old Feb 22, 2016 | 01:14 PM
  #31
10 Second Club
Any information/pictures pertaining to the fuel rail you used?
Old Feb 22, 2016 | 04:30 PM
  #32
genxhunter's Avatar
I used a NNBS rail with the corvette filter and 36 lb flex fuel injectors. My setup is just like the one in this picture. I retuned it for the new setup but am still having the spitting and sputtering issue that I can't figure out.
Old Feb 22, 2016 | 04:35 PM
  #33
10 Second Club
Got it, I have a 2011 intake and fuel rails that I want to swap onto my 2001. Trying to decide on the best option for fuel rails.
Old Feb 22, 2016 | 06:51 PM
  #34
Wolftrk99's Avatar
What is your fuel pressure??
Old Feb 22, 2016 | 07:24 PM
  #35
genxhunter's Avatar
58 lbs at idle. I found a gauge I think is long enough to check it while running down the road. I'll see what it does tomorrow. I'll probably end up replacing the rubber hose eventually as it popped off once already.
Old Feb 22, 2016 | 08:04 PM
  #36
Wolftrk99's Avatar
Yeah make it longer and get the "repair" fittings that fit the fuel filter.... Ill take close ups here in a few when i go work on my valve spring swap.... Nevermind you can see em in the pictures... Thats my intake... Lol
Old Feb 23, 2016 | 07:15 PM
  #37
genxhunter's Avatar
I have these on it and it still popped off.
Old Feb 23, 2016 | 08:48 PM
  #38
1FastBrick's Avatar
Custm2500's Rude Friend
Anyone have any ideas? I changed the mass airflow sensor also put it wasn't that either. Still searching for the sputtering problem.
Where did you get your injector Data from?
Old Feb 23, 2016 | 11:58 PM
  #39
Wolftrk99's Avatar
Those look about like the ones i have are you sure theyre the right size
Old Feb 24, 2016 | 12:45 PM
  #40
genxhunter's Avatar
I am having problems finding the correct injector data as the tunes for a gen IV injector data is listed as "injector offset vs pressure delta vs IGNV" and for the gen III trucks it's listed as "injector offset vs battery voltage vs KPA VAC". I am using some data from an 06 TBSS truck but these are not flex fuel injectors. I have a feeling that this is most of my issue. I'll keep looking around but if anyone has any suggestions, I would appreciate it. The injectors I am using are PN 12594512.
