in-tank fuel pump
I own a 2002 5.3 silverado with a intercooled procharger and i need to replace my in tank fuel pump. the procharger kit came with an in-line fuel pump which is still good. I would like to replace my in tank pump with a bigger one any help would really be helpful thank you.
i've asked before but i will ask again, with this walbro gss340, is everything included that u need to install it? and where can u get one and what is the part number?? i need a new fuel pump and my gauge sender is bad, will this fix both problems?
Walbro GSS340???
is this the kit that or p/n that comes with the Walbro 255lph pump??? I'm not too sure, but i think it is the same pump(255 liters per hour)
The Racetronix plug n play kit doesn't work for most of our trucks, so you are going to have to find out your Fule Pump p/n# and look into that.
Since this doesn't work for my Truck, I am going to just buy the Walbro in-tank 255lph pump and wire it up(not hard at all, but takes some modification)
Originally Posted by chris99gmc
Walbro GSS340???
Originally Posted by moregrip
If you called Magnacharger, they could send you their "fuel pump in tank kit" that keeps the installtion clean and includes all parts needed for the GSS340 swap, you would be set. Instructions are on there website
I just recieved my GSS340 intank kit from magnacharger today. Looks like everything is there thats needed. It was 123 bux. Can't wait to put it in.
Nate
Yep ordered it right from magnacharger in CA. I don't know the part number, just asked them for the GSS340, same that they ship in the supercharger kits for the trucks and H2. The dude knew just want i wanted. It came with the pump, a fitting, sock, electrical connectors, etc etc. Directions for install are on magnachargers website.
Nate
Nate
