swap question
Old Aug 17, 2008 | 05:20 PM
GMCtrk's Avatar
Same injectors, if you plan to add a cam, boltons and whatever you will need bigger injectors and a set of 8.1's or the marine 8.1's injectors. If you ever plan on going FI I would go with a lq4 since it has lower comp, will be a lil more boost friendly. Either way if you get a pre 05 or whatever, they will take what ever you can put at them for the most part. You can find a 05 up for 1200 or less if you look. I picked mine up for 1200 shipped to me with 11k on it..
John
Through all of my searching, I NEVER saw an 05 up LQ4 that cheap. The going rate for an 05 up is $1700 minimum nowadays. LQ9's command $2000 minimum.
The absolute best prices I found were from a guy on LS1tech: form>function. He had an 06 LQ9 with 35k for $1700 picked up. He is in detroit so it was too far for me. He also has fresh 06/07 LS2's for $2400 shipped.
Old Aug 17, 2008 | 05:32 PM
JHZ28's Avatar
how can u tell if its a lq4 or a lq9? are the numbers on the block some where
Old Aug 17, 2008 | 05:37 PM
Mangled03gmc's Avatar
Baltimore Whore
You just havn't found the one yet. I picked mine up on ebay from a company called midwest parts I believe. They are def out there, maybe I got lucky, if so that doesn't happen alot for me. LOL
The pistons are flat tops in the9 and dished in the 4's. They both use the 317 heads... Pull a head or look threw the plug hole with a mini cam.
John
Old Aug 17, 2008 | 05:42 PM
JHZ28's Avatar
i found a long block on ebay it from a 02. just wanted to know what i was buying, before i bought it
Old Aug 17, 2008 | 06:28 PM
GMCtrk's Avatar
02 is good. If you get a LQ4 just remember it won't hook up directly to a 60e.
Old Aug 17, 2008 | 07:22 PM
Truckshop's Avatar
yes it will. leave out the spacer and use the 5.3 flywheel. as long as it has aluminum heads.
Old Aug 17, 2008 | 08:09 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Z28RPM
U can use any of the LQ4 or LQ9 engines
99-00 6.0's have a longer crankshaft and won't work with a 4L60E
Old Aug 17, 2008 | 08:49 PM
GMCtrk's Avatar
Thanks for proving my point. Don't want him to get the engine all the way in and then find out the 60e doesn't hook up without the above mods.
Old Jan 18, 2009 | 01:11 PM
INresponse's Avatar
Just looking. Thanks for the info.
creekrat
Aug 2, 2015 01:27 AM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
bsn1989
Jul 16, 2015 08:20 AM
