Stock valves size?
Old Jul 10, 2006 | 05:38 AM
Default Stock valves size?
What are the stock valve size on 5.3 (706) heads?
BTW what our the bigger valves you can put on these heads?
Old Jul 10, 2006 | 07:45 AM
tdrumm's Avatar
Stock are 1.89 intake and 1.55 exhaust.
I went with 1.95 intake and 1.57 exhaust. You can go up to 2.00 on the intake, but you start to run into valve shrouding.
Old Jul 10, 2006 | 10:47 AM
SS_bnoon_SS's Avatar
I'll be running 2.08 and 1.60 in 5.3 heads, but on a larger bore 6.0L. I need to sell some more things on Ebay to pay for the machine shop to rough in the bowls so that I can start my port work, then have the valve job done... so many projects, so little time...
Old Jul 10, 2006 | 01:55 PM
These heads are probably gonna go on a iron block 5.3L stroked to 5.7L or in a stroked 6.0 forged 370 with all the goodies capable of holding a 250 or 300 shot of n2o
Old Jul 10, 2006 | 02:07 PM
FYI, your stroke will remain the same going from 5.3 to 5.7L as it's just the bore that's punched out to 99mm (standard bore for LS1). I've been thinking about picking up a 4.8 truck with a 5 speed and doing the 99mm bore with forged rotating assembly too!!!
Old Jul 10, 2006 | 02:18 PM
tdrumm's Avatar
In that case, take advantage of the bigger bore and step up to 2.02 or so intake.
Old Jul 10, 2006 | 02:22 PM
Yes that bored out to 5.7 not stroked my bad. My bro is not sure if he is getting the 5.7 or the 370, which one should be better, both engines are forged btw?
Old Jul 10, 2006 | 02:24 PM
What about exhaust?
Old Jul 10, 2006 | 03:10 PM
tdrumm's Avatar
What about exhaust?
I would think 1.57 would be sufficient.
The_W
Oct 28, 2015 09:00 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
4B11T
Jul 13, 2015 03:48 PM
jrplz
Jul 9, 2015 12:07 AM
zaathur151
Jul 6, 2015 10:57 PM
