Still in search of more low end TQ for towing, have 2 ideas.
Old Mar 27, 2006 | 08:10 AM
Default Still in search of more low end TQ for towing, have 2 ideas.
I am looking for more low end TQ for towing easier. On the highway I am around 2K rpms and want more TQ at that rpm. Dont get me wrong, it tows 5-6K easy and hardly downshifts on mild hills. I just want it to go smoother and get moving easier. I guess I spoiled myself with over 600rwtq on the cummins.
My thoughts are-----advance the stock can 2-4* to move the curves down. I know ir works with big cams but not sure about aftermarket. My second thought is a set of 1.85 rockers. They are supposed to add hp and TQ throughout the rpm range. I swapped from 1.5 to 1.6 on an old 4.3 I had and it was a pretty big difference, will the 5.3 be the same?
Old Mar 27, 2006 | 09:12 AM
YenkoST's Avatar
If you have the money....you can't beat the low end torque of a Radix, if you don't already have it.
Old Mar 27, 2006 | 10:51 AM
Gordy M's Avatar
Another angle to look at is the trans. Put the vette servo for the 1/2 and a Billit OD servo in. This will help on the initial start up and keeping it in OD longer without the constant up/down shifting. Also, a transgo kit will help. For a stock engine, good mid length headers will help (Thorley's come to mind) and a good towing tune
Old Mar 27, 2006 | 05:46 PM
14 Second Truck Club
Going from 3.42 to 3.90 gears was a big increase for me. With the set-up I have, I actually get better gas mileage in town and on the highway.
Old Mar 27, 2006 | 05:50 PM
Seeing Red Again's Avatar
If no FI then gears would be the next best thing, though pricey in a 4x4 since you have to do the front and rear together.
I picked up some noticeable low end torque with my long tubes but not a whole lot.
Old Mar 27, 2006 | 06:12 PM
so you finnaly have some mods on your truck. So you only dropped .3 in the 1/4 with all those mods?
I would think about gears but i'm sure I have 3.73's now and I also dont want to loose my 21.4mpg with 4.10's.
Old Mar 27, 2006 | 07:55 PM
goshawk23's Avatar
Truck addict
i never lost any mileage when i did the 4.10 swap. i did notice that i could pull a lot easier than before. but if you have the 3.73s now then you probably won't notice too much of a difference
Old Mar 28, 2006 | 05:56 PM
Yeah, I was expecting more out of the crane tuner, plus I can't come anywhere close to hitting the same 1/4 mile times in NC as I could in FL. The elevation is not that much different but in stock form I would do good to get under a 15.0 up here. Strange!
21 MPG! I wouldn't want to screw with that either!
2500ZL1
Jan 25, 2016 06:30 AM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
Dirtywhite
Aug 5, 2015 04:10 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
