Squeaking motor--sounds like idler pulley maybe
Old Aug 22, 2006 | 08:59 AM
BLACKND's Avatar
Default Squeaking motor--sounds like idler pulley maybe
Okay, I've noticed recently that when I start my truck in the mornings that I hear an annoying squeaking sound. I know it has to be the idler pulley that everyone talks about, it usually goes away after the truck warms up, but its embarrasing as hell to have it done when out somewhere.
Anyone change this themselves and if so, how difficult and part numbers for the replacement?????
Old Aug 22, 2006 | 09:21 AM
shupe's Avatar
Default pully
I swaped mine out. About 10 bucks at the local autoparts store and about 2 minutes later installed. Easy. Installed new belt while I was at it.
Old Aug 22, 2006 | 09:44 AM
Wilde Racing's Avatar
How do I change this text
You can use some wd-40 with the "power straw" (little red tube) to spray the back side of the idlers while the engine is running. Just be careful of the fan and belts. A safer way is to remove the belt and check each pully by hand........with the engine off....lol
Old Aug 22, 2006 | 09:52 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, I don't have part numbers for ya, but I've done both my upper and lower idler pullies for noises. Actually the top one was replaced under warranty, and they threw a new belt on also. From the looks of it, it's about a ten minute job. It had the same noise you mentioned, squeaking when cold.
The lower, ac idler started to make a jackhammer noise when the a/c was engaged. Picked that part up at the dealer (can't remember the price, but it was cheap), and two bolts later the noise was fixed.
You could try lubing it like Wilde mentioned to try and save yourself a few bucks. Like he said, do it with the engine off, and just try to squeeze the lube into the center of the pulley, keep the lube off the belts and outer edge of the pulley. It may work, it may come back, but it's worth a try for free.
Old Aug 22, 2006 | 10:03 AM
NO NO do lube it to save money.... Lube it to find out which one is causing the noise. THEN replace it ASAP!.
Old Aug 22, 2006 | 10:59 AM
LS1TRUCKGUY's Avatar
the only thing that squeaked on mine was the old belt....... pullies were fine
Old Aug 22, 2006 | 11:24 AM
Ambrosia's Avatar
My pulleys and belt weren't bad, that's what the dealership figured and replaced them but it didn't cure the squeak. I had to get a new alternator and have the belt tightened to spec.
Old Aug 22, 2006 | 12:13 PM
BLACKND's Avatar
I know its not the belts, they are both brand new.
Old Aug 22, 2006 | 04:27 PM
budhayes3's Avatar
PT's Slowest Truck
Whoops...sorry, misinterpreted that. I'm assuming that we're saying that the squeak is the beginning sound of a pulley that will eventually sieze...my bad.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
