Spintech mufflers
Old Jun 4, 2003 | 12:57 PM
Scream's Avatar
MOOBIES Moderator
Default Spintech mufflers
I heard an LT1 F-body last night with Spintech mufflers, and man was I impressed.
Anyone running Spintech mufflers on a truck? What is the inlet/outlet size and position so I can order one? Any sponsors carry the individual mufflers? Anywhere that I can get one if sponsors don't carry them?
Thanks!
Old Jun 4, 2003 | 01:07 PM
BigJ's Avatar
Default Re: Spintech mufflers
http://www.spintechmufflers.com/spin...ntechindex.asp
Let me know if you go with these, I've been thinking about changing mufflers again, and would like to see how these perform.
Old Jun 4, 2003 | 01:11 PM
Scream's Avatar
MOOBIES Moderator
what is the inlet/outlet size of the muffler? I've heard 2.5 and 3 inch...which is correct?
Old Jun 4, 2003 | 01:41 PM
BigJ's Avatar
I would run 2.5" with these trucks. I've learned that a small amount of backpressure is needed to keep some lowend torque. 3" may be too much. I'm not sure what setup your running, but I'm happy with my 2.5" size. I did loose some lowend, but I'm also running straight through design mufflers. I'm not sure which size to go with, the mufflers on there site look like they might be a little big to run 2 mufflers... You wanna be the guinea pig?
Old Jun 4, 2003 | 01:49 PM
Scream's Avatar
MOOBIES Moderator
I'm almost sure that I'm going to order one. I would run duals, but with a slammed truck, I don't have a lot of options!
I'll be the guinea pig!
Old Jun 4, 2003 | 04:37 PM
go with the spintech pro streets, they are very small and low profile, probably good for lowered trucks, and they sound good
Old Jun 4, 2003 | 04:43 PM
whitez71's Avatar
Stock size is 2.75"
Old Jun 4, 2003 | 05:11 PM
tinman's Avatar
Here's a link to a brochure I got from them.
http://www.netmechanix.com/eric/imag...erado15001.jpg
Old Jun 5, 2003 | 09:52 AM
Scream's Avatar
MOOBIES Moderator
Thanks for the info!
Old Jun 5, 2003 | 07:20 PM
tinman's Avatar
I've got a set with the X-Pipe on order. I'll let you know what I think when I get them on.
