Speed Engineering True Dual Exhaust Prototype..
Old Nov 22, 2015 | 12:19 PM
  #241
Ken in AZ's Avatar
Question though....Do I leave the rear O2 sensors plugged in and zip tied up and away, or can I unclip them and not use them at all?
Old Nov 22, 2015 | 05:34 PM
  #242
Tig's Avatar
Tig
Damnit Ken, you had post pictures. Makes me want it even more.
Looks awesome.
Now, lets hear it
Not sure about the sensors. I think you can tune out those sensors. Someone please correct me if I'm wrong.
Old Nov 22, 2015 | 07:42 PM
  #243
Wolftrk99's Avatar
Ok the different angles of the extensions pipes going under that funky rear crossmember are messing with me, i think id want them in same direction, gives more ds clearance..... No 4l80 clearance issues??? Kit looks good though.....
Old Nov 23, 2015 | 11:23 AM
  #244
Speed Engineering's Avatar
Former Vendor
MrHorsepowerLSx: We should have enough for 2-3 months of sales.
GM_Devil: Everything is coming in January.
Ken in AZ: The O2 sensor is suppose to go in the front bung, however our last batch of 99-06 1 7/8" headers had the O2 bung pushed to far back. The rear bung is normally used for wideband tuning. We discussed it in detail in the sponsor forum. Our new batch should have this issue resolved.
Wolftrk99: The connection pipes were designed to follow the same path as the drivers side connection pipe. Basically they both S around the crossmember together. He just accidentally put one underneath. If you look at the video you can barely see what it looks like. Those will only be on the 99-06 extra cab, and crew cab. I just threw them on my truck since I didn't have the straight pipes on hand.
Thanks
Sean
Old Nov 23, 2015 | 12:25 PM
  #245
Wolftrk99's Avatar
I may end up just going with this kit after all
Old Nov 23, 2015 | 11:27 PM
  #246
Ken in AZ's Avatar
I should still be OK running the O2 sensor there right? I'm guessing that it won't heat up as quickly being there....but that should only effect cold starts.
And yes, I ran the connection pipes funky to gain some ground clearance....they should be run parallel for aesthetics.
Old Nov 23, 2015 | 11:39 PM
  #247
MrHorsepowerLSx's Avatar
11 Second Club
Hey ken, can you post some pics of the installed kit from the back to the front view as well? From the rear bumper foward
Old Dec 2, 2015 | 02:14 PM
  #248
Rise of the Phoenix's Avatar
I'll be ordering a set of the long tube headers for my new 2001 5.3 Silverado. Right now, are they only made in 1 3/4", or do you also have 1 7/8"? I may end up going with your dual exhaust setup too if I can't make the existing exhaust setup work.
Old Dec 2, 2015 | 02:44 PM
  #249
Tig's Avatar
Tig
Headers & Y-Pipes - Exhaust - 1999-13 LSX Trucks - Shop By Vehicle
They havem all, hah
Might as well get the dual set up and use what you have to finish it off.
Old Dec 10, 2015 | 09:15 PM
  #250
Smokymance's Avatar
wish it fit ARH...
