Speed Engineering True Dual Exhaust Prototype..
Old Nov 15, 2015 | 12:56 PM
  #221
Tig's Avatar
Tig
Haha, I was thinking of going with the 14568. Its a bit bigger but I'm good with that. I have used them in the past and have been pleased with the sound.
I'm not a fan of dumps, especially in an SUV.
Old Nov 15, 2015 | 01:20 PM
  #222
Wolftrk99's Avatar
Dumps are obnoxious and if they are in the wrong place, do nothing but heat up an axle which in turn kills an axle bearing quickly!!!
Old Nov 18, 2015 | 10:50 AM
  #223
MrHorsepowerLSx's Avatar
11 Second Club
Do you have proof of this? "Killing axle bearings" that is. And yes dumps are loud as ****, they get old quick......... Like around the block quick
Old Nov 18, 2015 | 11:19 AM
  #224
dsmmace's Avatar
You haven't seen a glowing red diff or discoloration on the metal pieces behind the exhaust exit? This can easily happen after a WOT run or highway/freeway trips.
Old Nov 18, 2015 | 12:34 PM
  #225
Wolftrk99's Avatar
Same truck came in probably 5 times in 6 months needing axle bearings all on right side.... After 4th time they refused to cover it under parts warranty, because all of them were cooked, last time he had to pay for it, he also went and had tailpipes put on it and hasnt toasted a bearing since.... Wish i had pics, but was a while back....
Old Nov 19, 2015 | 12:41 PM
  #226
11 Second Club
No I haven't seen it. Have you?? And I would never point my dump/turn down at my axle housing or tube end either. And I highly doubt speed inc. is going to sell a product that will damage drivetrain pieces due to heat exposure. Even if you axle is "glowing" that right there is a sign that you need to reconfigure you exhaust and continue to run the same setup. Also noting, there are plenty of trucks on this forum that run dumped, turned down exhaust and have never had damaged bearing issues. Exhaust gasses that far back from the motor aren't nearly enough to make the axle housing glow. Watch some dyno videos, the headers glow, and a few inches past the collectors glow(barely) but if you are glowing the whole length, like stated, there is an issue there. And a WOT pass isn't nearly enough time to cherry that cast iron housing, and neither is freeway driving, this is more then enough air flow passing under/around the vehicle to keep the temps at a reasonable temp.
Old Nov 19, 2015 | 12:47 PM
  #227
Wolftrk99's Avatar
Agreed, was more a caution or warning, than sayin their dumps would be or are pointed at axle..... Biggest concern is the obnoxious factor for some..... Just nature of dumped system!!!
Old Nov 19, 2015 | 04:51 PM
  #228
11 Second Club
I will agree with you that dumps/turn downs are a bit much for some folks. My self included...... Even tho I have a turndown, it is quite obnoxious. Hence the reason Sean needs to hurry up with this kit so I can swap my exhaust, and make tail pipes if I choose
Old Nov 19, 2015 | 05:20 PM
  #229
Wolftrk99's Avatar
couldnt agree more!!!! At least with prices on the full system and just the crossover pipe and the little extebsion pipe for the driver side!!!
Old Nov 19, 2015 | 07:04 PM
  #230
Speed Engineering's Avatar
Former Vendor
Well, unfortunately we received some bad news this afternoon. We were expecting a normal eta with this kit. However, we just have been informed that the factory was having a hard time getting large quantities of all the pieces needed for the kit, and they pushed it back on their priority list. They have since gathered everything needed, and gave us arrival date of Mid January.
Thank you
Sean
