some pics of GM's 3 Valve heads
Old Jul 31, 2004 | 07:31 PM
PSM's Avatar
PSM
Default some pics of GM's 3 Valve heads
3 valve
this could make some very nice strokers
Old Jul 31, 2004 | 07:41 PM
gcooper's Avatar
Looks like they are following ford. The new rockers are a pretty trick setup. Hope comp is on it.
Old Jul 31, 2004 | 08:07 PM
retsell's Avatar
That can't be a working model.
I see a couple of serious problems.
The pushrod for the exhaust valve is plain scary and it appears 1 pushrod controls two valves. That's alot of pressure.
I am not sure but it also appears that the rocker assembly IS separated per cylinder, but the valves in each chamber open at the same time (exhaust and Intake)
Is this for real, or just "eye-candy"
More info pleaseeeee......
This guy says that both intake and exhaust valves open at the same time. This is not true, look, both exhaust valves are on the same side and the intake is on the opposite, and who cares if one pushrod opens 2 valves as long as the lifters, and pushrods are capable. We change out stock springs for aftermarkets that have over twice the tension, no difference here.
Old Jul 31, 2004 | 08:44 PM
XLR8NSS's Avatar
Adkoonerstrator
These pictures were in the internal engine section here a long time ago. It was a design test engine and was made as a truck setup.
Anyway, I think that setup was said to have been tested up to 8000 rpm with no problems.
Here is a thread with some stuff about it. Don't mind the LS2 reference, it is NOT a LS2.
https://ls1tech.com/forums/showthread.php?t=126769
Here is the thread with the pictures in it. The engine is NOT a LS6 like mentioned at one point in this thread.
https://ls1tech.com/forums/showthread.php?t=116049
Old Jul 31, 2004 | 10:41 PM
GoatChs's Avatar
Actually, it appears that the head has two intake valves and a single exhaust valve (located above and in line with the exhaust port).
Old Jul 31, 2004 | 10:44 PM
XLR8NSS's Avatar
Adkoonerstrator
Yep, you're right. I meant to say something about that in my last post.
Old Aug 1, 2004 | 12:22 AM
pman's Avatar
11 Second Club
there will be a V10 model of this head in the 2500s in a few years. I have both the V8 and V10 head castings at work...we are doing some prototype work on the rightnow.
Old Aug 1, 2004 | 06:18 AM
dkubricht's Avatar
why dont they do 4 valves like the 32valve cadie engine?
Old Aug 1, 2004 | 12:42 PM
Round Rock TA's Avatar
4 cams vs just 1
Old Aug 1, 2004 | 01:43 PM
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Round Rock TA
4 cams vs just 1
Check the heads out being talked about in this thread. 4 valves could work with one cam just as easily as the 3 valves are.
