So what shoud i do next. Heads or new headers???
Old May 20, 2011 | 09:52 PM
TXsilverado's Avatar
Originally Posted by BlackGMC
Yep you put down close to 400 with those headers qnd the PRC heads. That is the direction i am leaning towards. I might throw a 224/230 xer cam in at the same time
and i made 441 with less cubes and a weaker head. the exhaust is a choke point.
Old May 20, 2011 | 09:56 PM
BlackGMC's Avatar
Resident Retard
What size were you running at the time? Was your cr ~11.0?
Old May 20, 2011 | 09:57 PM
dlt76028's Avatar
yea but funny thing is you never went faster after all that exhaust work
hirdlej's Avatar
I'll let you know what kind of difference heads make Corey. No one bought my AFR's I had for sale so they're going on this week
Old May 20, 2011 | 10:16 PM
i havent made a winter pass in about 4 years. my 12.2 times were in -1800 da. i think the best ive been in since then was +8xx since then.
Old May 20, 2011 | 10:34 PM
yeah 11.0:1 compression. went from pacesetters with single 3" exhaust through a cutout to kooks 1 7/8 stepped 2" with true dual 3" exhaust through mufflers.
in this dyno graph, changes were the new exhaust and LS6 manifold to Fast 90 manifold. everyone figured i would lose bigtime down low with this combo of parts, but gain big up top. it was actually the exact opposite.
Old May 20, 2011 | 11:30 PM
fastrt's Avatar
11 Second Truck Club
I am with stewart on this one....both. at one point or the other you will need both. If you do heads, you will need more header, and make it at least a 64cc head. compression is fun. I also think you can do better than PRC heads IMO. A cheap set of 243/799 stock heads with LS6 valves, and get the TSP 1 7/8 headers with any cam of your choice, and you should make 400+. And cheaper than a set of PRC heads.
Old May 20, 2011 | 11:59 PM
Spoolin's Avatar
GFYS and STFU
I vote for a set of heads for the biggest gain since your just stepping up from one set of LT's to a bigger set. If you had stock manifolds on there than I would say headers.
Old May 21, 2011 | 01:07 AM
06Sierra2's Avatar
This is what i am thinking. Get the heads and then get the bigger lt's later.
Old May 21, 2011 | 01:17 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm gonna say better headers and exhaust first also. I just don't see any point in going to better heads, without going to VERY VERY GOOD heads. At that point, the headers you have will not be good enough, and they will be choking your engine.
