Should I Change To A Lighter Wheel?
Old Oct 1, 2004 | 01:21 PM
nativetexan's Avatar
13 Second Truck Club
Default Should I Change To A Lighter Wheel?
OK Guys,
I'm thinking of changing from my factory 20" chrome wheels to some 20" Centerlines that weigh approximately 13 lbs less (each). Is there any noticeable performance advantage from this swap? Lower ET? Better launch? Higher mpg?
Old Oct 1, 2004 | 01:28 PM
Originally Posted by nativetexan
OK Guys,
well i may still be a noob but im sure everyone will agree you WILL accelerate and brake better than before. just not sure how much. 13x4=52lbs of unsprung weight lost. i think thats pretty freakin good.
Old Oct 1, 2004 | 02:10 PM
it will lower it somewhat, what would really make a difference is using a smallr tire, thats the problem I ran into with my regular cab, also my vho doesn't have the decals like yours. looks good.
Old Oct 1, 2004 | 02:13 PM
In chevy high performance they gained .11 sec, and I think .12 mph by changing to some centerlines that took 12 lbs off each wheel on an SS.
Old Oct 1, 2004 | 02:14 PM
Does this vho have the same HC 6.0 as my ss? AWD? very sharp looking truck you two have....
Old Oct 1, 2004 | 02:16 PM
i would not call .11 enough to matter. screw it, get a baer brake upgrade and call it a day.
Old Oct 1, 2004 | 02:21 PM
That is exactly what I was looking for. Thanks for the compliments and help.
The VHO is 2wd with the LQ9, 4L65E, and 3.73 gears. It is somewhat similar to the SS.
Old Oct 1, 2004 | 02:24 PM
with out the awd, same suspension jsut looks plain on the outside except the 20's. it's a wolf in sheeps clothing more or less.
Old Oct 1, 2004 | 03:48 PM
chris99gmc's Avatar
My wheels/tires I am sure way well over 70 or 75 pounds each.....
Just throw on the Baer 14" EradiStop rotors like I did and you'll be set. I stop better than stock now even with the oew brake pads and calipers.
Old Oct 1, 2004 | 04:29 PM
the ss awd system hurts our 1/4 times a tad but i think the stock equipped 4:10s help out
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
thunder550
Oct 8, 2015 04:53 PM
Hmguyton
Aug 9, 2015 05:38 PM
