Service 4x4 light
Old Jan 27, 2005 | 07:10 PM
Dark Eternal's Avatar
Default Service 4x4 light
As some of you may know, I have completly ripped out my 4x4 system that came in my truck. No more transfer case (well with sensors) and no more front diff. Now I get a service 4x4 light in the message center. I tried flashing the PCM with a 2wd tune, but this didnt do anything. Anyone know a way to turn this thing off? I know very little about the electronics in these vehicles, but figure i can cross some wires or smething to turn this off. Any ideas?
Old Jan 27, 2005 | 09:31 PM
wrencher's Avatar
wrencher
See if the bulb in the cluster is removable?
Old Jan 27, 2005 | 09:39 PM
03NHSilvy's Avatar
Well the comp. is looking for a signal from the sensors that were in the factory 4x4 system. I have no idea how to cure this, maybe getting a 2WD comp?
Old Jan 27, 2005 | 10:17 PM
Its not a bulb, its in the message center.
I have a 2wd computer in it, I have a Nelson tune and had him flash it with a 2wd flash. Didnt do anything.
Old Jan 28, 2005 | 01:09 AM
Zick's Avatar
I believe someone was able to unplug the message center from behind. Not positive though.
Old Jan 28, 2005 | 03:37 AM
L-EATER's Avatar
11 Second Truck Club
I am thinking that it might be controlled through the BCM and not the PCM therefore that is why the 2wd tune didn't fix it. If this is the case you will have to have the stealer reprogram the BCM to a 2wd VIN. Just thinking out loud,it is 330am and I am not awake yet so I might be off base.
Old Jan 28, 2005 | 05:02 PM
KeukaZ71's Avatar
put the 4WD back in j/k
Old Jan 28, 2005 | 05:15 PM
BigTex's Avatar
Have you removed the Transfer Case Control Module fuse from the underhood fuse box?
Perhaps these will help you figure out which wires to cross:
http://z71.net/tccm.tif
http://z71.net/tccm1.tif
http://z71.net/tccm2.tif
Old Jan 28, 2005 | 08:01 PM
Update. I did remove the fuse and it didnt do anything. Last night I tore into my dash and found the TCCM itself. It has 2 plugs, once both were unplugged and the ECM reset the light went off. It was not fun getting to the TCCM, they sure to bury it in the dash.
ARC
57
Feb 21, 2022 10:54 AM
bk_cauley
40
Aug 17, 2018 05:45 PM
Corvette454l88
Sep 1, 2016 01:24 AM
JCW
Sep 22, 2015 03:59 PM
97aztecgt
Aug 13, 2015 02:11 PM
