running my true duals with lt pacesetters
Old Feb 26, 2008 | 10:40 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by Dark Halo
I see, now I running a true 3" dual set up on a LQ9 with 11.1 compression and a 230/236/.591/.601 110lsa cam and stage 2 patriot heads do you think my exhaust is over kill?
Honestly I was speaking for more stock to bolt-on type of engines, what kinda track times do you see with that combo, sounds nasty... What size header primary are you running?
Old Feb 26, 2008 | 11:08 PM
jkwalkercchs's Avatar
thats cheatin my answer was for the stock guy u got bigg enuf motor to run whatever u want lol
Old Feb 27, 2008 | 02:54 PM
have almost all the bolt ons, i have 22" wheels and i tow my drag car to the track. just looking for more power
Old Feb 27, 2008 | 05:08 PM
black4.8's Avatar
thats what i run. probably not the best hp set up, but damn it sounds good. not much loss down low, just don't use 3" pipe use 2 1/2". if you worry about low end loss use
2 1/4" pipe.
Old Feb 27, 2008 | 05:27 PM
LowBlack99's Avatar
Just a single muffler turned down still sounds great with the lt's and no cat. You could split it after the y-pipe and put a second muffler on but IMO you'd just be adding restricion with the second muffler.
Old Feb 27, 2008 | 05:41 PM
99LoweredSierra's Avatar
Just go 2 1/2 if you got full bolt ons and and I think that would be a good set-up.. Gonna go with a X pipe correct?
Old Feb 27, 2008 | 11:15 PM
fastrt's Avatar
11 Second Truck Club
yes make sure you xpipe it or hpipe it. go with 2.5 or 2.25. as long as you do 2 mufflers it will sound good. I had about the same setup but with a dual in dual out magnaflow and xpipe. it was ok, I did not like the muffler. now I have 3" ory and a 22" 5x11 case magnaflow and no cats, and it is quiet...very....quiet. ran thetips out the side in front of the rear tire. like this
Raggedz71
Jul 29, 2016 10:20 AM
stealthperf
34
Feb 14, 2016 11:35 AM
thewrx
Aug 12, 2015 08:28 PM
Zack R
Aug 3, 2015 06:02 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
