rocker torq specs and crank bolt probs.
Old Sep 5, 2003 | 07:08 PM
lifted99GMC's Avatar
Default rocker torq specs and crank bolt probs.
First, im putting a cam in my 99 GMC 5.3 L truck. i have everything off BUT the crank hub/balancer. Im trying to get the center bolt out that screws into the crank, i cannot get it. i first tried an impact, then a breaker bar, then a breaker bar with a 2 ft extension. before i get too crazy with it, is there a trick to this? is it reverse threaded or something? Also, could someone give me the torque spec on tightening the rocker arm stud nuts? thanks
Chad
Old Sep 5, 2003 | 08:48 PM
1BADHD's Avatar
Default Re: rocker torq specs and crank bolt probs.
A breaker bar and a whole bunch of a$$ is the only thing that will get that bolt broke loose.
Old Sep 5, 2003 | 09:19 PM
CashDudeHomie's Avatar
Try wedging a lug wrench with the curved end into the pulley and the straight end into the cement and braced against the crossmember. Then I pulled like an SOB but it came out easier than I expected. Once you get the crank to stop turning you can get better leverage. I used a 2 foot handle with a 2 foot exhaust pipe over it
Old Sep 5, 2003 | 09:48 PM
BigTex's Avatar
Make sure you are turning it conuter clockwise. 240 foot pounds is not the easiest thing to break free.
Old Sep 5, 2003 | 09:49 PM
BigTex's Avatar
Oh yeah, I forgot: 22 ft pounds on the rocker arms. I gave mine 26 or so for good measure.
Old Sep 6, 2003 | 12:51 PM
allright, a$$ its gonna get. I borrowed a 3/4" drive breaker bar from work. thanks for the info guys
Chad
Jblake
Aug 17, 2015 12:59 PM
vipergtrdj
Aug 6, 2015 10:19 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
GreyChevy
Jul 7, 2015 08:57 PM
